OEM Head gakset thickness
15GaurdGT
Rhode Island
Dom
2015 Mustang GT
Anyone know what the thickness is on an OEM head gasket? Motor from JPC has .045 min gasket written on it. I have new stock gaskets but I can't find the thickness.
Thanks.
Elp_jc
None
I was under the understanding there are O-ring type gaskets now, but maybe just Gen3s? Or are they?
engineermike
La
2018 GTPP A10
I know someone who measured them and reported .040 on a used set, not compressed. I’ve been trying to figure out the compressed thickness myself. When I run the numbers using actual deck height and piston dome and chamber volumes reported by Mahle, the only way I can get to ford’s advertised compression ratio is with .030.
15GaurdGT
15GaurdGT
Rhode Island
Dom
2015 Mustang GT
Its very possible the number they gave me is uncompressed.
GregO
Illinois
S550 GTPP
Advertised head gasket thickness is the compressed thickness.
GregO
Illinois
S550 GTPP
Just thinking out loud;
It's possible Mahle's numbers are skewed a bit ?
Wrist pin height and crevice volume come to mind.
engineermike
La
2018 GTPP A10
I don’t know, but what I’m going off of is this:
Bore: 3.66
Stroke 3.65
Gasket bore: 3.7
Compressed gasket: .040
Chamber: 59 (mahle catalog page 16)
Dome: 8.4 (mahle catalog page 16)
Deck height: 0.015 (measured)
CR= 11.45. Ford says 12/1. Substitute in .030 and it yields 11.76/1.
I’m as interested as you are and I’ve dug deep trying to figure this out.
engineermike
La
2018 GTPP A10
Even more irritating is that does sells a “thicker” head gasket but doesn’t list the thickness of it either.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Bore: 3.66
Stroke 3.65
Gasket bore: 3.7
Is the deck height above or below the deck?
If above the deck -.015 the comp ratio is 11.92
engineermike
La
2018 GTPP A10
That’s interesting. The gen3 has a bigger dome and larger bore. You’d think they’d be heavier.
engineermike
La
2018 GTPP A10
Thought the gen3 chamber volume was 57 cc.
I don’t know but the mahle catalog definitely lists gen2 as 57 and gen3 as 59.
.040 and 57 cc would make it 11.8 though. .030 and 57 would be 12.1.
