Octane/Timing relationships
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
BUT what is the control octane number ?
There isn't. Whatever number you have then go with the chart.
So if it is at the edge of knock on 87 and you increase the air temp 7c you now need 88. Same if you started with 100 ect..
At least that is how I read it.
as far as needing one knock number per 1 degree of spark advance, that seems a bit conservative. Even knock limited.
engineermike
La
2018 GTPP A10
Some they’re talking delta octane numbers the absolute value is irrelevant.
engineermike
La
2018 GTPP A10
Notice that 1 compression number is worth about the same octane as direct injection. Thus, the cr and di introduced together in the gen3.
Jasonb543
Detroit
Jason
1993 fox
Learn to read spark plugs, the engine will show you.
WildHorse
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
I literally just did that. Everything is primo. That Octanium sure leaves an orange-ish deposits though ha-ha.
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
All depends how that DI is used.
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Can you explain?
Is the DI active in conjunction the port injection at all times ? Or on only low load, low rpm ? Only WOT ? Only at WOT with port injection ?
engineermike
La
2018 GTPP A10
Since I mentioned the gen3, I can tell you how ford does it if that’s what you’re after. Though my base case assumption and the assumption in the table is that di is added for the purpose of suppressing knock so implementing in ways that would not suppress knock would be, well, silly. I can also tell you that the Gen4 (if that’s what we’re calling it) has an additional table that adds borderline timing with gdi blend % and the values align well with the table.
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
So now we know.
Lot of tooners say the FORDS DI just gets in the way. And that theres better ways of tackling knock.
engineermike
La
2018 GTPP A10
There is literally no other reason to add DI.
The easy-button for tooners is E85 because it basically doesn't knock and tuning DI is something most aren't familiar with.
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Literally the Toyota D-4S & many others use PFI & DFI in conjunction.
So, it appears the knock suppression isn't the only reason.
Joshinator99
Massachusetts
Josh
2022 Mustang GT Premium, 2017 Camaro 2SS
So now we know.
DI makes more power than PFI every day of the week and twice on Sunday. Check out Brian Tooley Racings videos on this, they did back to back dyno tests in the same engine using different fueling combinations, and the DI always made the most power. As they scaled in more PFI fueling, the power dropped accordingly. DI allows for more compression, less knock, and less air volume taken up carrying fuel. An all-DI engine will net roughly 10% more power than an all-PFI engine. The more you blend towards DI the more power you will make.
Joshinator99
Massachusetts
Josh
Could not agree more! Us Camaro guys are DI-only from GM and I can tell you the learning curve is very real, and so many GM owners still do not grasp it. Very expensive to upgrade too unfortunately.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Surprising that table gives so many octane points for altitude. I thought that was outdated info?
