pulling timing
robmustang201528
15 mustang gt302blown
LA
15pp
Pulling timing what does that mean? Tuner said the car wasn't spark knocking but it was pulling timing?
Grimace427
NoVA
2011 Mustang 5.0
The PCM can alter ignition timing(when the spark plug fires in relation to the combustion cycle) based on many things within the tune as well as corrections for fuel and other parameters. When the PCM is pulling timing it means it is detecting knock whether it be from poor fuel to ghost knock such as from a bad exhaust leak or something else.
Honestly these are questions to be asking your tuner directly.
95cobby
Houston, TX
2015 Mustang GT PP
Pulling timing refers to a reduction/delay in the spark plug being ignited. Usually from low octane fuel, knock, running rich, boosted applications, etc. It reduces the power of the car and helps prevent detonation or harm to the engine.
robmustang201528
LA
15pp
Oh ok. He said I probably got bad gas. Yeah I asked him, I just want to see what other people thought about it. He said he wasn't getting any spark knock but it was pulling timing. Cant be an exhaust leak haven't changed exhaust yet. But is it possible for the car to pull timing out without spark knock is the question I think im trying to ask lol
UPRSteve
Lake Worth, FL
www.uprproducts.com
15 GT
Timing can also be pulled on how its commanded in the tune.
If you look at Spark and Spark v2 on a datalog, that will show you what it's actual seeing and what it was commanded to see.
robmustang201528
LA
15pp
Should I be worried? Im thinking about running the gas out putting some different gas in and put it back on the dyno
VNMOUS1
New Smyrna Beach, Florida
www.vmpprformance.com
bj
2007 GT500, 2017 EcoBoost Mustang, 2017 Focus RS
If it were bad gas you'd very likely see some knock sensor activity. There are a number of things that can pull timing, but the most frequently seen are knock sensor, temp and torque mgt.
But, as mentioned, talk directly with your calibrator and have them lay it out for you.
bj
UPRSteve
Lake Worth, FL
www.uprproducts.com
15 GT
bj
x2
beefcake
Bethel
2018 Ford Mustang
it's all based on what the cars seeing in the fuel, all cars will add or pull based on what it's seeing
cbear50
dfw
2015 mustang 5.0
Im running the roush phase 1 on my car and I've Wondered if my tune on my car would pull timing based on the torque management sensors. I swear sometimes my car seems much spunkier than others but I could be just getting used to the extra power. I feel if I ease into the throttle the car feels much stronger than if I just slam it to the floor.
Hope that tune shows up soon Beef, wanting to see how the throttle response changes.
VNMOUS1
bj
That's probably heat.
cbear50
dfw
2015 mustang 5.0
I live in Texas so your probably right.
So are you saying the car is pulling timing because of the heat or just FI cars just battle heat in general and that is the performance difference?
I'm a fan of your kits and I'm sure you have some suggestions to keep that heat in check.
Burningcoals
Seattle
2015 Mustang GT PP, 401a
High IAT (Intake Air Temps) will lower octane, which increases knock, which then causes the ECU to pull timing. Or any combination of the above.
Supercharges with superior cooling and recovery will be more consistent pull to pull.
Consider running higher octane fuel in heat or running meth injection to cool the charge or act as secondary fuel. Or beef up your cooling ability.
