No throttle response in 6th gear
trs6803
trs6803
Tyler
2018 Shelby GT350
Really hoping this is the fix. I paid more for an almost new car, hoping to prevent this very problem. I will keep the thread up to date as I get new info. Thanks.
torque124
Torque
MA
Shelby GT350R
I never knew about such problem, mine is a 16 track pack... it's obviously not going to pull your face in sixth gear, that gear is extremely tall. It felt the same on my previous Shelby the GT500, so I just ignored the feeling.
Good luck ; please let us know if the car feels better after.
TDC
Long Island
2016 GT350, 2019 Challenger Scat Pack Widebody, 2019 Corvette Grand Sport
Crammer I hear ya man. But just spoke to the dealer. They believe it’s a backed out flange nut that monitors something with the transmission. Apparently there is a TSB for it which I’m attaching a screenshot of. They said the part is on back order because it is so new.
This is what was fixed on my car. Sometimes a symptom is the cruise control works intermittently. Mine had that symptom.
mavisky
Cumming, GA
Kyle
2018 GT350
This is not a torquey car. I never shift to 6th unless I'm over 75mph. Anything else is 5th gear. This car prefers to be around 3,000 rpm. at 65mph in 6th gear I'd be under 2,000 RPM and the car would hate it. I downshift from 6th fo 5th at around the 70mph mark. Below there I have to be in 5th.
TomcatDriver
Mojave Desert
2017 GT350 Magnetic w/black stripes
It's not torquey down low, but it should accelerate in 6th, some. Mine does. If you have the cruise control on steady state at 65 the car is just fine tooling along at 1800 rpm. Yes, if you want to pass you need to downshift, but it should accelerate some in 60th, albeit slowly.
firestarter2
NYC
RR G350 Track
When my transmission went I lost all acceleration it was very strange. It came back and I could drive home but for that moment it was like the car was dead in the water.
whatjones911
Bay Area
Pretty Fast
When I first bought the vehicle, 6th gear was different. I could accelerate with no problem. Now I hit the pedal and the rpms don’t change even if I put it to the floor. It’s very strange. No codes
Flooring it in 6th at highway speeds? Yikes. Don't do that.
mavisky
Cumming, GA
Kyle
2018 GT350
Just re-read the thread and didn't realize it wasn't accelerating at all. I thought he was just exaggerating. I've heard plenty of people complain that "there's so little torque down low that it just doesn't accelerate" when what they really mean is that it doesn't accelerate the way a 5.0 would.
Spart
Midwest
17 GT350
This kind of makes sense.
From experience, if you change your tire size in FORScan without doing a PCM relearn, you'll run into issues with deadbands in the RPM range in certain gears, and it's down to a signal mismatch like it says in the TSB.
It's a weird feeling, it's as though the car is ignoring the throttle. WOT, doesn't matter, doesn't even change the pitch of the intake/exhaust. Just nothing.
Hope they get you figured out. :beer:
Tank
9/11 - Never Forget
Above the Notches
G0853
I recently bought a used 2018 GT350 with 2500 miles on it. 4 days after buying it I switched into 6th gear at around 60-65 mph and had no throttle response. I mash the petal and nothing. I know 6th is a cruising gear but I can’t accelerate at all. 5th gear seems to lack power and the car sounds bogged down. Took it right to a Ford Dealership and they have had it for 3 days with no answers. Has anyone else experienced anything like this? Thanks for any help.
Any update?
trs6803
trs6803
Tyler
2018 Shelby GT350
No update. The dealership hasn’t got the part in yet. I’ve been driving the car and haven’t had any other issues with it. Same thing in 6th tho.
TDC
Long Island
Below is a video and at the 1:44-1:46 mark you could hear the power interruption in 5th gear (it happens right before I let off the gas for the braking zone). Was fixed when the dealer replaced the sensor on the tranny tail shaft under warranty.
trs6803
trs6803
Tyler
2018 Shelby GT350
The part finally came in and was replaced, with no success. I was able to drive the tech working on it and he agreed there is definitely an issue with 6th gear. Every other gear seems fine. I was at 92 mph, switched from 5th to 6th and slammed the pedal repeatedly. The car had zero response, RPM’s did not budge and the exhaust sounds bogged. He stated that it seems like the car is electronically not allowing it to accelerate in 6th. Still no codes. He checked MY KEY to see if that may be limiting something and the car has 0 MY KEYS. Back to square 1
TDC
Long Island
Sorry to hear this. These electronic gremlins are frustrating.
trs6803
trs6803
Tyler
2018 Shelby GT350
The dealership has had my car for a week and still no fix for the problem with 6th gear. They said sometimes a Ford Engineer will come out, if they can’t figure it out. They have been accommodating with a loaner vehicle and such but, I’m starting to get frustrated. The car has been at the dealer 3-4 times now. Anyone have experience with the lemon law process? I’m not sure how to proceed from here.
