Modifying As-Built Data Guide
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
Have looked here and in the Sync 3 swap thread with no luck... somehow I turned off the radio and phone steering wheel controls. Anyone know offhand what module controls this, or which digit to check?
TexasRebel
Gearshifter
between the mustard and the mayo
2016 YZ GTPP - PP2
With some of the issues arising from mixing different year as-built modifications I would like to reiterate to anyone considering as-built mods:
Make one change at a time and check the function.
Save a copy of your original as-built data. Don't rely on the data stored at motorcraftservice.com as it is not a permanent record; it can be altered during a service visit.
And as always, if you don't have a solid understanding of how your vehicle uses the as-built data, please reconsider. These modifications are in no way "programming" the car, they merely configure the car to use existing programming.
19 RKT PONY
Rensselaer, NY
19 Bullitt, Tech PKG, MagnaRide!
I have a simple request, looking at the "as-built values spreadsheet" Im confused as to what value to change. I would like to have power plug on dash console turn off with key, Instead of run for a continuous amount of time.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Has anyone figured out how to keep the gear indicator on all the time?
Apparently Lund can make it work. 1.30 in the video. At 4.10 it shows him driving in D with the gear display on.
i8iridium
Pat
2020 Mustang GT
This value should lower it to 1 second. I think that there's been some issues with setting it to 0. In my F-150 I've never had consistent results when testing. I've never had a reason to try on the mustang, so please post back if it works for you.
0726-39-010001xxxxxxxx
19 RKT PONY
Rensselaer, NY
Thanks I'll give it try, & post back
K4fxd
NKY
Gear indicator on always.
I haven't been able to find it in ForScan but I did find it in my tuning software.
It is in the TCM section of HP tuners.
The car is much more comfortable to drive. I hated not knowing what gear I was in.
Auto trans.
K4fxd
NKY
It is in Trans>General>Display>Gear enable
So for the auto trans folks, that gear display can now be enabled via Forscan? If so this is excellent news!
What is the actual value change to be made?
K4fxd
NKY
I can't find it in forscan. I used HPtuners.
It is in the TCM. I don't know forscan well enough to know if it can access that unit. If it can someone should be able to find it.
ponie1992
Elgin, SC
2016 Ruby Red PP GT
I tried looking through this thread to see if the boost gauge was available for my base model 2016 PP GT. Some said it wouldn't show in the PP cluster. I tried it today and it works. Just wanted to share. I only changed the 6 to a 7 in the first group of numbers. This is in the IPC module.
Chappers
Sutton Coldfield, UK
Greg
Toyota Supra MkV - Tungsten Silver
ask someone to take their as built data with that setting enabled and compare your IPC values against it, bear in mind options etc you need to identify any differences and which they pertain using the spreadsheets on the internet as a guide.
