Modifying As-Built Data Guide
zuki_dan
North Carolina
15 Mustang GT Premium M6 TY
Somehow this is the first I've heard of this, what does it do?
[MENTION=25607]Spart[/MENTION]I had seen it previously mentioned and figured I would enable it to see if it would work like a digital speedo. It does not act like that it is truly a average speed indicator that averages the speed digitally in the IPC center screen since the last reset. Press and hold to reset like the other trip info. It was kind of disappointing.:tsk: It shows up under the trip menu in the center display.
So will that change add an "average speed" display option for a 2015-16?
[MENTION=20679]HoosierDaddy[/MENTION] Yes, I turned it on on my '15.
awmustang
Milwaukee, WI
2017 EcoBoost Premium PP
^ It comes as a standard gauge (at least in my 2017 EcoBoost)
Where do you find it? I have a 17 Ecoboost and I don't see it.
AngelDeath
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
Finished my Sync 3 swap today and renewed my Forscan license a few weeks ago.
Switched APIM to the Ford blue GT theme, 7D0-01-01 xxxx x4xx xxxx.
Ford Performance GT splash screen, 7D0-03-01 xxxx xDxx xxxx.
Turned on the heated/cooled seats in Sync 3, 7D0-01-01 xxxx xxxx x2xx
Auto relock doors, 726-15-02 0101 01001 0149 & 720-01-01 xxxx 5xxx xxxx
Power point time out disable, 726-39-01 xxxx x0xx xxxx
Average speed indicator, 720-01-01 xxxx x4xx xxxx
Panic alarm 2-presses, 726-37-01 xxxx xxx1 xxxx
I also tried secure idle with my manual trans, 726-42-01 x1xx xxxx xxxx, this does nothing with the manual trans. I was hoping it would cut the car off when the clutch was depressed of limit the throttle to idle. I was able to drive the car still with no key fob in the car.
The Auto re-lock setting, is that for after you get out of the car, or is that for relocking after unlocking the doors and not opening it in 45 seconds?
MakStang
Greece
www.cellentis.uk
Makis
A 2017 miraculous little beast
You can find it under the trip menu in the center display (IPC). It was activated on my car when I bought it. Seems to work fine, although I never use it LOL!
Nuked
Morgantown, WV
2016 Triple Yellow GTPP w/Recaros
It will relock if you don't open a door in certain time period.
buzz-dee
Germany
15 GT Premium PP
Yes Sir! It is standard on European Mustangs. I added it on my US that way. It shows up in your IPC. Scroll down from the Trip 1 screen. When you reach the bottom of the menu it shows you the remaining miles on your current fuel fill.
And if you change the aforementioned option through forscan it will show average speed ass an added menu below the remaining miles
Abb0nz
Houston, Tx
Paul
2017 GT
DRLs - Fogs not working
Hey team,
Something to be aware of when enabling the fog lights as DRLs. For the DRLs to come on the light switch has to be in auto mode. I just spent a lot of time with the car in my garage (so it could be connected to the battery charger) messing with it. Because the lights were on (because it was in the garage) I turned the light switch off thinking this was irrelevant in regard to the DRLs being on... it's not irrelevant... sigh.
I was in the process of writing a post here when I thought to try the car outside and it worked, but only when the switch was changed to auto.
Paul
soldier989
Columbus OH
2017 GTPP Premium
I saw the 2018 cluster has a digital MPH readout (and halos). Guess Ford was listening.
Spartanator
Kemah, Texas
2014 Stage 3 Roush
Iv'e looked through the thread again. Anyone tried the fuel prime on door code from the F150 sheets?
726-41-01 xxxx x*xx xxxx Fuel Prime on Door Ajar Cfg: 0=no prime, 1=prime
Also interested in a soft touch button for the rear camera:
D0-02-02 xxxx x*xx xxxx Camera Toggle Button (CTB) & Trailer Reverse Guidance (TRG) & CHMSL Camera & Aux Camera
54
0=CTB hard & TRG disabled & CHMSL disabled & Aux Camera disabled
8=CTB soft & TRG disabled & CHMSL disabled & Aux Camera disabled
55
1=CTB hard & TRG disabled & CHMSL disabled & Aux Camera enabled 9=CTB soft & TRG disabled & CHMSL disabled & Aux Camera enabled
56
2=CTB hard & TRG disabled & CHMSL enabled & Aux Camera disabled A=CTB soft & TRG disabled & CHMSL enabled & Aux Camera disabled
57
3=CTB hard & TRG disabled & CHMSL enabled & Aux Camera enabled B=CTB soft & TRG disabled & CHMSL enabled & Aux Camera enabled
58
4=CTB hard & TRG enabled & CHMSL disabled & Aux Camera disabled C=CTB soft & TRG enabled & CHMSL disabled & Aux Camera disabled
59
5=CTB hard & TRG enabled & CHMSL disabled & Aux Camera enabled D=CTB soft & TRG enabled & CHMSL disabled & Aux Camera enabled
60
6=CTB hard & TRG enabled & CHMSL enabled & Aux Camera disabled E=CTB soft & TRG enabled & CHMSL disabled & Aux Camera disabled
61
7=CTB hard & TRG enabled & CHMSL enabled & Aux Camera enabled F=CTB soft & TRG enabled & CHMSL enabled & Aux Camera enabled
awmustang
Milwaukee, WI
Under the trip mode
Nope, I don't have it.
When I go over to the Trip/Fuel Screens I have Trip 1, Trip 2, Fuel Economy, and Fuel History. There's no average speed.
Must be an EU only thing.
Bill88stang
2016 deep impact blue premium gt 6 speed manual
I know it’s off topic but forscan relates can you do a KAM reset on it?
Boggus
Cypress
16 Mustang GT PP
How about adding the lines back to a replacement backup camera? Can it be done via Forscan
buzz-dee
Germany
15 GT Premium PP
Did you make the change with Forscan?
IPC 720-01-01 xxxx x4xx xxxx
I did it on my US spec Mustang and it shows up now.
It's activated by default on EU spec cars only.
papinist
The Italian Pony
Tuscany, Italy
Stefano
Mustang EcoBoost MT Race Red EURO - NO MORE
One of the few (useless) things that EU Mustangs have over US specs :doh:
