Minimum pulley size
blaisa
Marion, KY
Andy
2017 Mustang GT/CS, 1970 Camaro, 2019 Mustang Eco
I have and am installing a fully forged RPG Gen 3 Coyote for a 3-2-2 build built to 11 to 1 specs. I also have a gen 5 3.0 Whipple. LTH 1 7/8" headers no cats and a double pump in tank return fuel system. Looking for 1000 WHP out of my automatic 17 Mustang. I need to know what is the smallest pulley I can run with 93 octane with 1 or 2 cans of boostane added. I know E85 would be much preferred but it isn't available close to me.
Any real experience advice would be appreciated.
engineermike
La
2018 GTPP A10
That's a tall order.
To make 1000 rwhp on a Whipple 3.0 would require something like a 2.5" or 2.6" pulley.
A couple of issues stand out to me.
1. It's doubtful a 6-rib belt will work well with that small of a pulley. I guess you could try but it seems that under a 3" it's generally recommended to upgrade to a 10-rib. My friend broke a couple of 6-rib belts on the 3" pulley but I haven't, so even at 3" it's hit-or-miss for the 6-rib.
2. I don't think many would recommend attempting 1000 rwhp on a witch's brew of pump gas. You're talking 11/1 compression, 20+ psi boost, and 20+ deg timing. That's asking for a lot from a gas-station cocktail.
3. You might consider lowering the compression if you're stuck with pump gas. You could probably get up past 800 on true pump gas at 9.5/1, though most tuners won't touch it. Conversely, lowering compression will make it a little harder to reach the ultimate goal of 1000.
RiotfunK
mass
Binx
22 mustang GT Premium PP1 Manual
Any tracks by you for race fuel? Don’t think that’s gonna last long trying to push that much power out of 93 tune
Joshinator99
Massachusetts
Josh
2022 Mustang GT Premium, 2017 Camaro 2SS
This. Compression closer to 10:1 would help a lot if you’re stuck with 93.
Timbuck
Australia
Tim
2017 s550 6r80
Direct port water/methanol would be a safer option instead of a pump gas cocktail.
diambo4life
OKC
2014 Mustang GT 1998 GSX
Absolutely not. 3.5" is the very max I would attempt and that is nowhere close to 1000whp. Now with meth injection, you could make that 1000whp with a great tune.
xr4x4ti
Minnesota
Tim
AWD 2017 Mustang GT 6MT Supercharged.
If are putting the long block together yourself, you could put a thicker head gasket in to drop the compression. I think @engineermike has done some calculations on that.
I will be playing around with a similar setup this summer. I have a 9.5:1 gen 3 Aluminator and I am going to install a Gen 6 Whipple and planning on 800+ to the wheels on 93.
Joshinator99
Massachusetts
Josh
Be careful. A thicker head gasket can push your quench distance into undesirable territory, making your car *more* detonation prone… the opposite of what you’re trying to do.
