Mantic vs McLeod vs lpxHD
Gurupitka
Michigan
Nate
2015 mustang gt 2021 powerboost
Hello I am in search for a clutch here for my setup,
currently running a whipple on pump gas but will move over to e85 sometime this year.
currently 624 wheel hp with and no plans to exceed 900 wheel, I’d like to settle in at 750-850 range.
what clutches are you guys running? How do they compare to a stock feel?
is the Mantic 9000 really worth the extra money? Anyone run more than one of these to compare?
beefcake
Bethel
2018 Ford Mustang
silverbullet85
San Diego
2019 Gt
I've seen a few issues and personally had the issue where the mantic cerametalic clutch for the 18+ d4 does not disengage properly out of gear. I haven't heard of a specific fix, so 15 and up mantic 18 up would go with mcleod or centerforce myself.
J17GT
IL
2017 Mustang GT PP
I’ve used to run the lpx hd, I liked the engagement, but did not like that it was a solid hub. I now run a sprung hub Mcleod RXT with my Magnum XL and really don’t care for it. Some seam to love mantic, others have had issues.
I think you’ll find good and bad with just about every clutch manufacturer which makes it tough. If I ever need to drop my trans again, the RXT is not going back it. But honestly have no idea what I’d replace it with. LOL
Justgonna send it
NC
Ty
2019 GT 6spd ess G3 kit 120mm pulley , wendgerd tune & 2020 hpp eco
Again don’t sleep on vengeance. No chatter , smooth engagement, bad ass flywheel.
NGOT8R
Adrian
2019 Bullitt
How’s clutch pedal feel with the LPXHD and McLeod RXT, hard, soft or Goldilocks?
Zrussian13
Phoenix
What about the solid hub didn’t you like on the lpxhd? And why don't you like the RTX?
J17GT
IL
2017 Mustang GT PP
The lpxhd has a bit more heavier pedal than the RXT. The RXT 1200 would be comparable to the lpxhd.
Didn't like the gear rollover noise at low rpm with the solid hub. I'm running a sprung hub version of the RXT with my Magnum XL. Zero noise from it at all, but the engagement is tricky. Chatters pretty decent if you're not perfect with it. My engagement also seems to change, sometimes close to the floor, other times higher on the pedal. I'm confident there is zero air in the hydraulics, I think the floater plate drags at times. But high rpm shifting, there is zero issue with it.
Racinjason65
Huntington Beach
Jason
2020 Mustang GT Premium PP1M-82
I just got one of my cars back with an RXT 1200 and I really like it, my other car is in for extensive mods and Is getting a Tilton twin disc rated for 1250 torque
Sins550
GA
2015 Mustang 5.0 PP
I have Exedy ET04XD hypertwin disc, wanted to be different. Clutch pedal feels like stock and holds the power just fine. The initial bite just takes getting used to when coming from a stock clutch..probably like any other twin disc+ clutch but no big deal.
beefcake
Bethel
2018 Ford Mustang
it’s another great option
SheepDog
Colorado
Dax
Check out the Spec clutch offerings too. I had the SS trim in my 2017 GT. It was perfect.
@beefcake sells them as well. https://www.beefcakeracing.com/spec-sf50sst-2/
AZlb5.0
Arizona
Carlos
18 GT Premium
Im actually going with a spec with the GTO. I hear nothing but great things form everyone who has it. The GTO isn’t highly modded but she’s a heffer. 4100 lbs with me and fluids.
beefcake
Bethel
2018 Ford Mustang
let me know!
