Lund Emissions Tune
CompOrangeFanatic
Delaware
2015 Mustang GT Premium /2019 Toyota Camry XSE V6
I’m going to throw out a thought on the anti-foulers. When I had my srt8 charger with Kooks LT’s and cats with built motor, I used to run anti-foulers with stainless steel steel wool lightly packed in them. This worked for me every time I had to get my car to pass emissions testing in DE. Has anyone tried this yet?
SAY WHAT
Tim
2016 mustang Gt
Sorry for reviving a dead thread but I just loaded my emissions tune from Lund and had all the monitors set in about 20 mins of driving. Mods jlt intake,18 manifold lu47s corsa cat back, stock cats.
kluke15
Reno, NV
Kenny
2017 Mustang GTPP
Sorry for reviving a dead thread but I just loaded my emissions tune from Lund and had all the monitors set in about 20 mins of driving. Mods jlt intake,18 manifold corsa cat back, stock cats.
The issue had been with cat deletes and headers w and w/o cats. With Stock cats there doesnt seem to be any issues
Zelek
Round Rock / Hutto, TX
2021 Mustang Mach 1
Yeah, Lund usually can get you dialed in on stock cats/headers. It's the long tubes that makes it trickier with or without cats. I think the OP had a strange case that could have been the tune, but not every car behaves the same way.
kluke15
Reno, NV
Kenny
2017 Mustang GTPP
Duffie112
Hudson Valley NY
S550
Did anyone happen to find a solution to the Lund emission tune and monitors not going green? I’m in the same boat cai, long tube headers and tune and can’t get the 02’s to go green. I had 120 miles on since I re flashed it to the emissions tune and still nothing. I just reflashed it again thinking it didn’t load right. Now I’m going to try to follow the drive cycle. Back and forth with Lund and they don’t have much to say besides put it to stock if it won’t pass...
jabrax
Montgomery County PA
Jeff
2015 ruby red PP GT
I assume you are catless headers. If just driving without doing drive cycle, it could take much longer than 120, just gotta get lucky. Do the cycle for the 02 portions.
If not catless and tune required cai, isnt it safe to put the stock on?
Duffie112
Hudson Valley NY
S550
I have mbrp catted long tube headers and a roush cold air intake with the adapter out. I’m not sure if going back to a stock tune with long tube headers and a cold air intake was an option. I just drove 60 miles after I reflashed the tune and everything is green except the big the 3 the evap and both o2’s.
jabrax
Jeff
2015 ruby red PP GT
Cool, sounds like you are on your way again :)
The Evap takes place in the first 30 mins after car has been down for awhile. I had to set that one on the second day just cruising up and down the highway with steady throttle - Also be sure tank is close to 3/4 fuel.
6. Cruise at 77 to 104 km/h (48 to 65 mph) for 10 minutes Executes the EVAP monitor if the intake air temperature is (avoid sharp turns and hills). NOTE: To initiate the monitor, between 4.4 to 37.8°C (40 to 100°F) the throttle should be at part throttle
Good luck - Hopefully you get pleasantly surprised
Duffie112
Hudson Valley NY
S550
Ok I figured I would have to do the evap after the car sat over night. What is the trick with the o2 and Ho2? How many miles is it before they go green? Any certain driving techniques to help them complete? Thanks for the help man!
Stymee
Delray Beach, Fl.
Joel
2019 Mustang GT
Just asking since you guys have tried to sort this stuff out, say I do a Flex Tune with the E85r tune if I ever race it in E85r? For sure I will with Flex...
The only mods I have are a AFe drop in filter and a h-pipe, everything else is stock.
My question is, one will I pass on the flex tune?
Or does the Ngauge save my stock tune when I load the flex, and would I have to put my stock tune back in to pass emissions?
I’m in Pa, stricter than Tx...
Just curious....
CEHollier
Prairieville, La.
Charles
2015 GT Premium Magnetic
Just curious....
For the Ngauge to load the Lund tune to your car it first loads your factory tune on the tuner. I have a Lund flex tune with all O2 sensors on. I also have my cats. I pass the Louisiana emission test verified via OBD2. If you don't delete your cats you should be ok. Check with Lund about your state. No matter where you live they will not promise you will pass.
jabrax
Jeff
2015 ruby red PP GT
Just curious....
Your stock tune should be on the Nguage. Just understand when you change tune you will have to drive for a bit to have monitors set. Shouldn't take long with the mods you have. I dont have experience with e85, so i dont know if the fuel you are running matters
CEHollier
Prairieville, La.
Charles
Just asking. Why install a Flex and E85 tune and keep switching back and forth? What do you hope to gain?
