Kooks vs American Racing Headers
Bcobb85
Houston, Texas
GT350
Hey guys! Trying to decide on which headers to go with. I'm in between American Racing and Kooks. I was originally 100% sold on the ARH ones but the more I look at the Kooks, the more I like. It seems the Kooks were developed with Ford Engineers specifically for the GT350 while the ARH are pretty much identical to the ones they offer for the 5.0.
Which do you prefer and why?
I've seen a few issues with the Kooks developing cracks but not sure how common that is, has anyone had the same issues with ARH?
Also, the header design itself is very different between both manufacturers, is one known to make more power than the other?
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Kooks didn't design them with Ford from what I know, but followed some guidance specifically for the 350 (i.e. adding the dampeners). That said, I run the ARH on my car which gets driven harder than most and haven't had any issues. Highly recommend.
Neither will make more power. The "big" power increase comes from removing the cats. OEM headers flow well enough for an N/A motor.
Bcobb85
Bcobb85
Houston, Texas
GT350
Thanks for the feedback! This is the article that I read that eluded to Kooks work with Ford to develop the headers... https://www.fordmuscle.com/tech-sto...gets-a-power-boost-from-kooks-custom-headers/
honeybadger
Just don't care
COTA
Kevin
'17 GT350
I read "Kooks has the ability to work closely with Ford’s engineering team" as a fairly loose statement. Could be wrong, but I didn't get the impression they're co-engineered or "blessed" by Ford. I'd assume either is a gamble. Given that I know a few guys who cracked Kooks headers, I chose to go with ARH.
From what I've seen, it looks like Kooks has better fitment but ARH is more durable.
Bcobb85
Bcobb85
Houston, Texas
GT350
Yea, its definitely wishy washy but when they mentioned working with Multimatic on the Roush car I made the assumption. I'm definitely leaning towards ARH mainly for the sound. I've watched alot of your vids and love the tone. The fact that you run the shit out of yours and haven't had any cracking issues gives me alot of confidence in the durability. What issues did you have fitment wise?
Bryanh24
2015 Mustang GT
Went with ARH on my car they are currently getting installed as we speak. Can’t wait to go pick it up!
Ninjak
Posting from the Shadows
The Shadows
David
2024 Dark Horse Supercharged 2024 Bronco Raptor 1968 GTA Mustang
I run Kooks was my first mod 2 weeks into ownership. No issues, and sounds really good. I also run a off road xpipe, no resonators, but the OEM mufflers
Bcobb85
Bcobb85
Houston, Texas
GT350
Any sound clips of your setup?
madlag
Snake Charmer
NC
2018 GT350R, 2022 GT500
Kooks is local to me and I know many there personally. They worked with Ford Performance directly on many aspects including their FPC crate motor "Aluminator" project. Having said that, their complete exhaust system for the 350 was rushed to market. I ended up having their R&D team build me a one off custom system that performed better and was much quieter than the public offering.
As for durability, last I checked the Kooks headers were built stronger using a stepped/graduated approach and included flex couplings for their X pipe where the ARH doesn't. That flex coupling is a must and will keep cracks from forming. just my 2 cents but I'd do Kooks every time if nothing else, for strength.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
We're probably getting into semantics, but I'd still bet there's some confusion here. Unless I missed it, there's no FPC crate motor "aluminator" project. The Aluminator is CPC and the Voodoo is the only FPC V8 Ford makes.
No doubt Kooks works with Ford on their race cars....but those are CPC. They could have worked on the GT350RC that was raced initially. Either way, I'm not seeing enough clarity on the matter for me to feel confident really betting on that either way.
Given the lack of clarity and official statements from Ford, I chose to go with real-world feedback that I could find. As mentioned earlier, I know a few who have cracked Kooks systems at the welds and no one with a broken ARH system (although fitment was sketchy for some).
Regarding your flex fitting statement, agreed that's a nice touch (as are the dampeners). But I'd argue that's mostly for the street. Most track cars don't use flex fittings (can fail under extreme heat) or the dampeners (loosen and fall off) based on my experience. Given that I've never seen the ARH headers fail, not sure a flex fitting is needed. Would be a lot easier during install, tho.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
I don't think my fitment issues were normal. Given the engine upgrades and extreme G's more car sees, the engine moves around a good bit. I was having very light contact with the frame rail. I just clearanced them a bit.
But I know others that had to send their's back in the early days. They've supposedly fixed the jog and it now fits correctly.
Bcobb85
Bcobb85
Houston, Texas
GT350
I don't my fitment issues were normal. Given the engine upgrades and extreme G's more car sees, the engine moves around a good bit. I was having very light contact with the frame rail. I just clearanced them a bit.
Thats good to hear. I saw that Alton had issues as he was one of the first to run them and they sent him a revised set. Was hoping they fixed the issues since.
madlag
Snake Charmer
NC
Yes I realize the aluminator is a cpc engine but my point is that they work closely with FP on a lot of different projects including the initial FPC engines. its one of the reasons they were some of first to market with an exhaust solution. They've actually revised their kit to remove dampeners as they cause more vibration than they solve for. The headers + the flex is all they need apparently. The construction of the header itself appears to be structurally superior. Agree on the flex pipe failure point.. I'll add that its the first thing to scrape road and shred. Def a maintenance thing to keep an eye on with it but worth it for longevity of system.
Edit to add for those that question the dampeners: I saw the harmonics/vibration numbers taken on my car and another like it but NA during development and testing. The difference was definitely there.
Bcobb85
Bcobb85
Houston, Texas
GT350
But even still, they removed them because they were doing more harm than good?
