Keep losing battery cover fasteners.
GT Pony
Pacific NW
Don’t you need a special tool to install those nuts? Don’t they expand like a rivet?
Just hammer them in the holes. They have splines/ridges on them that bite into the hole edges. Looks like the photo also shows the installation tool to hammer them into the holes.
johnscousin
Salisbury, NC
Jim
2017 LB Mustang GT PP
Where did you get the wingnut solution?
Thanks-jc
Lightning Struck
Waupun WI
2018 Kona Blue PP2
That's what the bolt with the flange nut is for. Thread the insert onto the bolt, hold the nut in place and back off the bolt. Effectively compressing the Rivnut like the proper tool would.
qtrracer
Greg
16 GT Premium PP Recaros; 86 GT 'Vert Pro-touring
I just leave them off. They are not needed to keep the cover in place.
Agreed. Lost my last fastener nearly two years ago. Not having them makes it a lot faster to lift the lid for tech at events.
Lorne34
Project Hidalgo
Wisconsin
Lorne
2019 GT350
problem with the plastic fasteners is the thread forks split and break off... if you don't compress them as you insert they hit the edges. Lost one this winter taking my battery tender on and off as my son needed to borrow it...
frank s
san diego CA
www.fsheff.com
frank
Stang '19 Magnetic, EcoBoost™, Vert, MagneRide® PP
There must be another thread about these wayward little fasteners, but I haven't found it. Any road I'll revivify this one and it'll come to the top. I distinctly remember someone posting that what these need is a slim washer, since the base in contact with the battery cover doesn't cover the hole, and they tend to slip into the holes. I agreed. You want your fasteners to have firm contact with the surfaces you're trying to connect. After a few losses of the skittering plastic items, I practiced and got it down to where I was only losing one pushpin per mount, dismount, mount of the cover.
That accomplishhment was enough to spur my interest in the base-to-hole size problem. I have a number of those cabinets, some of them inherited already full, with little drawers to hold extra screws nuts, cotter pins and so forth. During a systematic review of the contents of one cabinet I came across a drawer of flat washers, among which were three sort-of-slim plastic washers that looked as if they might fill the bill. Sure enough, they did the hole-size-reducing job, so the base of the fasteners no longer could find their way through the cover's holes.
Of course during the try-outs and mountings, I managed to lose one more pushpin—and one of the washers. OH NO! Yes I did. Now I had one too few washers. Rats! Looking more closely at the washers that remained, I saw they bore a part number. Google told me it was a VW part number for something to do with seatbelt mounting. And that a used VW parts store in SoCal would sell them to me for two bucks apiece. They came in the mail today. Definitely used, with surface blemishes from some kind of friction during that use. A couple were a bit dirty. I cleaned them with Windex, and preserved/lubricated them with ArmorAll. Looking good.
I'm doing a routine installation when—you guessed it—one pin escaped into the Bermuda Triangle of the engine compartment. No biggie; I had bought quite a few for just such happenstances. Two out of three in place and snug, now one of the washers, slippery from its ArmorAll bath escapes my trembly old fingers, similarly lubricated, and falls. Down. There. I could see it on what seems like a frame rail. No way to reach it without some kind of mechanical extension, Which was successful in dislodging the washer and allowing it to pass into oblivion. But I was ready with an extra washer, and now have the darned thing fastenered and washered the way I had daydreamed it.
Couple more notes:
Photos show the final assembly before final adjustment to center the pins in the washers.
I'll have to take the cover off before leaving the car for service; unwarned technicians are even more likely to let the fasteners and washers escape.
I'm wondering if my ArmorAll treatment has rendered the gluing of a washer to a pushpin impossible?
VW parts place also offers the washers in white; would they look too terrible under a black pushpin and on a black cover? Would certainly increase the chances of service personnel noticing their presence.
qtrracer
Greg
Been more that two years since mine disappeared. Cover doesn't move. I suppose if one needs to have the holes filled with something all of the above solutions satisfy the need. But the fasteners are not required to hold the cover in place.
plc268
Central Texas
Patrick
2015 Mustang GT Premium Race Red
Yea, I also just leave the fasteners off. I didn't lose them, but they're just flimsy and eventually break if you have to access the battery frequently.
I too thought about a fancy solution to replace the fasteners, but it's just a waste of money and the cover never moves.
Monopoly
Monopoly
Toronto
2017 Mustang GT, 2012 Civic Si
Same I just left them off. Screw it, after several mentioned it wont move then who cares!
frank s
san diego CA
www.fsheff.com
frank
"The satisfactions of manifesting oneself concretely in the world through manual competence have been known to make a man quiet and easy. They seem to relieve him of the felt need to offer chattering _interpretations_ of himself to vindicate his worth. He can simply point: the building stands, the car now runs, the lights are on. Boasting is what a boy does, because he has no real effect in the world ... "
-- Matthew B. Crawford, _SHOP CLASS AS SOULCRAFT: an inquiry into the value of work_
...the battery cover is secured in place, with improved elegance.
Costcocombo
2016 Ford Mustang Ecoboost Premium
i made a rookie mistake of removing the battery cover causing one fastener to fall through the opening between the battery and fender......Will anything happen to the car if it gets stuck there forever?
