Just lowered, questions about alignment.
daSNAK3
Cary, IL
Jake
2021 GT
I just lowered my car about an inch with SVE springs, trying to find a shop now for an alignment.. my question is will I need any plates or bolts to get this thing aligned in specJust rather be prepared before taking it to a shop if I do need to pickup some other stuff beforehand.
I don’t track the car, just a street car.
coz0502
Tampa Bay, FL
2016 Mustang GT PP
I also have the SVE lowering springs on my car and when I took it in for an alignment they couldn't get the front back in spec. It was close but not within the green range. I don't remember what was out of spec, but think it was caster, not camber.
I bought the caster / camber plates and rear brackets from BMR, wish I would have purchased these at the same time as the springs so I didn't need to pull the strut assemble out twice.
WItoTX
Houston
Kyle
'17 GT350
You might be in spec, you might not. Since everything is already installed, take it in and let them see what they can do for you.
The ideal way is to do camber plates so that way you can adjust front camber. If it isn't in spec, you could probably get camber bolts. The rear is fully adjustable (camber and toe), so don't let them tell you they couldn't get it into spec.
daSNAK3
daSNAK3
Cary, IL
Jake
2021 GT
Alright thanks, sounds like a plan, I’ll just take it in and see what’s up and go from there, if I gotta pull everything off and install more stuff later, then I will. I should have just done it all at once. 🤦🏻‍♂️
Bluemustang
2015 Mustang Base GT
The only way to adjust front camber is: slot the struts, use camber bolts, or use camber plates. The latter is the best option IMO. If you have to adjust it again, plates will come in handy and is a much safer connection than using camber bolts.
daSNAK3
daSNAK3
Cary, IL
Jake
2021 GT
any recommendations on plates?
brianbr
Surprise
Brian
2019 Magnetic GT PP
Camber bolts are the easiest/ cheapest. I'm using them with my SVE springs. They don't give a ton of adjustment but should get you back "in the green".
Bluemustang
I use Maximum Motorsports, but the J&M plates come highly recommended. Steeda camber plates are very commonly used around here and have good feedback. The first two you can also adjust caster, Steeda only camber is adjustable. Tbh any of the reputable brands would work just as well. I can't advise using camber bolts even though it will work and is cheap. It's just not as safe as the stock bolts.
