installing battery tenders
jpindustrie
NYC
a Ford Mustang
I just went through this exercise on my 350 , started with the clips because the cigarette lighter doesn't work like my buddy's Porsche does ...
I ended up getting the OBD connector and it seems to be able to float the battery fine via this method (I have a Noco g3500).
I don't know why I waited this long but it is very nice to not have to jump start it every time.
Tank
9/11 - Never Forget
Above the Notches
G0853
Bumping this up for the people that may be looking at these for the winter.
I recently got the Ctek 3300 off Amazon and got it hooked up.
Definitely happy with the performance of the unit as well, so we’ll see how it holds up over time!
Been using the CTEK wired as above for 5 winters now. Still working like a charm.
madlag
Snake Charmer
NC
2018 GT350R, 2022 GT500
This is how I have mine too. The only thing that bothers me about this set up, is if someone trips over the cord and bends the fender outward there at the headlight. that piece is weak...
Tank
9/11 - Never Forget
Above the Notches
G0853
Depending on how much slack, you could feed it ip through the hood and down the side....
I have a low traffic garage, essentially just me when it’s plugged in.
johnny1
I had it the same way on my 16 and 17 with brand Battery Tender. But you can buy an extended cord that is longer from them on there website that might reach through the hood and then down the side.
madlag
Snake Charmer
NC
I’m fairly low traffic too but have a rambunctious 7 yea old that loves the car hehe.
it’s been a while but I saw someone here actually put a more permanent plug into the cowl for easy access/unplug without raising the hood. Didn’t look bad and was super utilitarian. Can’t remember who it was tho.
JohnVallo
1 5 4 8 3 7 2 6
Venice, FL
racersreunion.com
'16 GT350, Shadow Black, Whipple Supercharged
Simple (But Clever) CTEK Battery Tender panel Install
cosmic charlie
Sunny Florida and Taxachussettes.
2019 Steeda Streetfighter Q850 NEED FOR GREEN, 2016 Focus RS (frozen white), 2016 Focus RS (stealth grey), 2014 Ford F150 Crewcab, 2015 Porsche Boxter GTS, 2013 Mercedez Benz ML350, 2003 Mercedes Benz C32AMG, 1989 Honda CRX Si Turbo
I just used the 2 loop connectors (instead of the alligator clips). Hooked them to the positive and negative on top of the battery (underneath the battery cover) and leave it there. Zip tied the female plug to the shock tower. Plug the tender in when needed. When not in use cover the connection. You don't even notice it's there.
Mustang_Phil
SoCal
Phi
2020 GT350
What are the pros and cons of directly hooking it up to the battery vs. the fusebox and ground point?
