Advertisement
installing battery tenders
Discussion in '5.2L V8 Voodoo Engine Mods & Bolt-Ons' started by Schredder, Jan 11, 2017.
  1. Schredder
    Schredder Well-Known Member
    Vehicle(s):
    2017 shelby gt 350
    Aug 11, 2016
    Maine
    64
    has anybody installed a battery tender to one of the positive terminals in the battery box. And if you have witch one did you attach it to. I seen a picture of someone that attached the positive into the fuse box and the ground to the spot outside the box. any info on this. Thanx.
  2. The Chairman
    The Chairman Well-Known Member
    Vehicle(s):
    ‘09 GT500KR & ‘16 GT350 Track Pack & ‘20 GT500 HP
    Mar 18, 2016
    South TX
    795
    545
    0   0   0
    I posted the pix where the wires were connected to the positive terminal on the fuse box and a nearby ground on the strut tower (top left corner of the second pix). Works great and is convenient to connect the tender. IMG_0295.jpg IMG_0296.jpg
    BlownGP likes this.
  3. OP
    Schredder
    Vehicle(s):
    2017 shelby gt 350
    Aug 11, 2016
    Maine
    64
    I like it , a clean look. I already put it to the battery. Next spring I'll move it to the fuse box. Just wanted to make sure it would not damage the system. Can't imagine that it would. Thanx JOHN
  4. NipSC4328
    NipSC4328 Well-Known Member
    First Name:
    Jim
    Vehicle(s):
    2020 GT500 Twister Orange w\ Black OTTS
    Feb 19, 2016
    Northern Oklahoma
    318
    134
    0   0   0
    Is the positive wire on the center post?
  5. The Chairman
    Vehicle(s):
    Mar 18, 2016
    South TX
    795
    545
    0   0   0
    The left of the three main posts goes to the battery. The small nut with the small red lead is what I added.
  6. NipSC4328
    First Name:
    Jim
    Vehicle(s):
    Feb 19, 2016
    Northern Oklahoma
    318
    134
    0   0   0
    Thanks! :cheers:
  7. littletex
    littletex New Member
    Vehicle(s):
    2017 GT350R
    Jun 20, 2016
    Denver
    This looks very good. Are is everyone using a CTEK? I planning for the winter months.
  8. STCoastie
    STCoastie Member
    First Name:
    Sean
    Vehicle(s):
    17 GT350, 07 Ram 3500, 02 Jeep Grand Cherokee
    Sep 1, 2017
    Fallon, NV
    I have heard good stuff about CTEK. I have used Battery Tender brand for years, never had problems, I stayed with them. No pics, but, I ran mine to the battery and ground to the factory ground on the strut tower, ran it in the loom, looks just fine. kind of wish I would have thought about the fuse box beforehand........
  9. Tank
    Tank 9/11 - Never Forget
    First Name:
    Jim
    Vehicle(s):
    G0853 Never Forget
    Feb 19, 2016
    New England
    2,811
    1,556
    0   0   0
    The CTEK 3300 comes w the pigtail that can be attached to the battery terminal post in the fuse box and ground on the passenger side inner fender. I’ve been using it for over a year w absolutely no problems. The pigtail has an attached cover to the quick disconnect so there’s no worries about open connections. When it’s in use, the line to the CTEK unit slides nicely under the fender above the headlight. (No, I do not have a financial stake in the company:D)
  10. Wriggly
    Wriggly Well-Known Member
    First Name:
    Vehicle(s):
    2018 Porsche 718 GTS
    Jul 17, 2016
    Illinois
    517
    219
    0   0   0
    I cut the round connectors on the Battery Tender pigtail into a "C" and loosened the nuts on the battery clamps just enough to slide them under and tightened them back up and works just fine.
  11. Nicky Pass
    Nicky Pass Well-Known Member
    Vehicle(s):
    2017 Avalanche Gray GT350
    Oct 8, 2016
    Chicago
    275
    135
    0   0   0
    What size nut did you use to make the positive connection? I really don't want to loosen the cable to get a ring connector under it.
  12. The Chairman
    Vehicle(s):
    Mar 18, 2016
    South TX
    795
    545
    0   0   0
    Actually, I couldn’t tell you. I have several containers of excess small parts and just tried a few small nuts until one was a match to the threads.
    I just measured it, and it appears to be a 6mm bolt.
    Nicky Pass likes this.
  13. Nicky Pass
    Vehicle(s):
    Oct 8, 2016
    Chicago
    275
    135
    0   0   0
    Thanks Chairman!
  14. GFoxHunter
    GFoxHunter Member
    First Name:
    George
    Vehicle(s):
    2017 Magnetic GT350 w/Recaro, Black stripes, stock
    Nov 23, 2017
    Midwest US
    Hi folks. This is my first post. Learning a lot from the community.
    Collected my Magnetic GT350 a few days ago. It will be in storage over the winter.
    Thanks for sharing.
    DocWalt likes this.
  15. dwalker
    dwalker Well-Known Member
    Vehicle(s):
    2017 GT350 white with blue stripes "H1807"
    Jan 14, 2014
    East TN
    1,130
    1,209
    0   0   0
    #15 dwalker, Dec 22, 2017
    Bumping this up for the people that may be looking at these for the winter.
    I recently got the Ctek 3300 off Amazon and got it hooked up. Works like a charm and the pigtail that has the ring style connectors works great and you can easily make the wires very inconspicuous. In the pics I’ve attached you can see that I used the ground on the shock tower and ran the power to the most rearward positive lead in the fuse box that’s coming from the battery. Ran the positive wire under the big harness coming into the fuse box so the fuse block for the Ctek unit is kind of hid under there.
    I really like the quick disconnect style plug it has on the pigtails. It also has a rubber plug that caps the end off when you unplug the pigtail from the unit to keep any moisture out. The wire is also small enough to run between the fender and headlight so you can shut your hood as well.
    Definitely happy with the performance of the unit as well, so we’ll see how it holds up over time!
    2JZFAN, saleen367, Tank and 2 others like this.
Loading...
Share This Page
