Anyone know the part number for the locking clip for the two smaller vacuum hoses?
:cheers:
Nice find!To throw a curve ball...Ford changed the vacuum lines up if your car was built after 8/25/16 (check your driver's door sticker for build date). You may not have a line at all and you were correct when you capped the extra one off.
Can you take a pic of the STOCK air intake tube or count how many total ports there are? I bet only 3 total if I'm correct. Prior to 8/24/16, there was 4 total.
Get yourself a blind grommet and you can remove the fitting all together. The blind grommet will be the same as a regular grommet except it has no hole in the center.
I can't seem to find it. Is it something I can find at autozone / advanced auto parts? Would you mind linking me to the exact piece you bought so I can show it to them?Get yourself a blind grommet and you can remove the fitting all together. The blind grommet will be the same as a regular grommet except it has no hole in the center.
I didn't have to buy one. The Air raid intakes come with one in the parts kit.I can't seem to find it. Is it something I can find at autozone / advanced auto parts? Would you mind linking me to the exact piece you bought so I can show it to them?
