jhatley7
You aren’t getting the swelling issues out of the Dw injectors by using fuel containing MTBE? All the big injectors clearly state, not compatible with MTBE.Yes. We have used them for years on that fuel
What injectors were used on this car?Hey guys.
Please see the attached video of Ken from PBD testing their first Street Sleeper kit, 746 rwhp on pump gas. This was done at sea level. Very comparable to the results we have here at 5500 ft of altitude. We stand by our use of the correction factor to compare vehicles. Please let us know if you have any other questions.
Your welcome!!!As a present Hellion customer with a 2018 GT that installed a Vortech JT V7 blower in June running 14 lbs. Now after purchasing the 62/66 Sleeper kit from Beefcake (purchased both from Beefcake) and now running 7-8 lbs. same setup with Fore Stage 2 E85 ID 1050x. Now with this said on 14 lbs. with Vortech made 920/700 This Sleeper kit feels very very very close to this on 7-8 lbs. If I were to put boost controller to 14 lbs on this Sleeper kit I have no idea what it would make but I can say it would make way more than 920/700 Thank you Hellion.
Hello,What injectors were used on this car?
First off, not calling BS.
However, I’m trying to understand how on the same boost - 8.3 psi, the twins made 370 more horsepower!! That is a HUGE difference! Did I read that correctly though, same boost!?
8.3 PSI is still 8.3 PSI. Even factoring in HP loss due to driving the supercharger and perhaps a little higher IATs (unknown though), I don’t see how that much of a gain is possible, at the same boost pressure. Unless their were other changes of course.
I do understand hp losses driving the supercharger and belt slip etc, efficiency... I just think 370 is really high for the same boost level.
If even half of the 370 difference, that would still be amazing at the same boost level!
So, I’m thinking that there were more changes or his supercharger was broke or the belt was actually just spinning and not really turning the supercharger very hard.
Make me a believer!! My winter project is FI.
Correct. I wasn't taking into consideration any specific engines or other restrictions. I was trying to correct some of the thinking here that boost is boost no matter what it producing it. Some people have a difficult time wrapping their heads around volume and boost.Except the water hose in this case is the exact same size - the throttle body and intake.
To flow more water or air in either, the pressure must go up.
