Hellion Twin Turbo Sleeper Kit
mech94
texas
2017 GT350
using turbosmart eboost 2 9psi on 93 still need to get some e85 since there is none at the gas stations around here and do my e85 tune
SupremeFocus
SupremeFocus
Los Angeles
19 GT PP1 10R80
Anyone know if it’s worth the $1500 to upgrade to the 62mm precision cea non ball bearing turbos ?
Zrussian13
Phoenix
Are you running 1 or 2 solenoids with your eboost2?
noshine4mine
East Texas
2019 GT A10 PP1 Hellion TT
running 2 4 port solenoids
I am waitting to get an engine back. Before the failure I was running waste gate only. While the car was down I installed an Eboost2 with two 4port solenoids. But after reading up about the 4 ports I switched them out for two 3 ports. My understanding is the resolution for the 4ports is worse than the 3 port so if you wanted to have fine adjustment of boost you would run the 3 port solenoids instead.
Why did you choose the 4 port solendoids over the 3 ports?
