Hellion Sleeper Kit
IceMan706
Virginia
Jacari
2021 Ford Mustang GT
How are you guys mounting your boost solenoids for the sleeper kit? I need a little inspiration for my setup.
NGOT8R
Adrian
2019 Bullitt
Please post pics and a write up of your TT setup build if you can. The more info. available on projects like these, the more helpful they can be to others looking to make that leap.
I’m about to begin work on mine soon and will do the same. Thanks
Cordero1
Kansas
Vic
2021 Mustang
Please pics and a write up of your TT setup build if you can. The more info. available on projects like these, the more helpful they can be to others looking to make that leap.
Does you kit require you to replace the a/c line? Slimmer radiator & moving fuse box is part of it correct?
NGOT8R
Adrian
2019 Bullitt
There’s no mention of replacing the AC lines on the 2018+, but I’ll have to evaluate the need to do so when I get to that step. I will keep the factory radiator (just move it forward with supplied brackets). The fuse panel can also stay in the factory location, but the PCM needs to be relocated. Here’s BL Fab’s PDF instructions.
Zrussian13
Phoenix
Are you running one or two solenoids? I run one on mine and have it mounted next to the battery under the cowl. There's a hole already there so it bolted up easy.
Cordero1
Kansas
Vic
2021 Mustang
I'd probably never go this route for many reasons & end up with a hellion or ess, but still looking forward to your build.
Cordero1
Kansas
Vic
2021 Mustang
Wow them are vague instructions & quiet a few things you have to discard.
Virgilbg
US
Virgil
How much was this kit?
Vandor
New Jersey
Thomas
I have a whole build log you can see under custom hellion turbo kit. I have detailed pics of the solenoids mounted but most people mount them in the upper rear of the front fender well behind the wheel bins.
IceMan706
Virginia
Jacari
would I have to drill my own holes behind the wheel well liner?
Vandor
New Jersey
Thomas
No there is holes already there for some reason and they tend to line up perfect with a ziptie.
IceMan706
Virginia
Jacari
Is there anyway you could show a picture of the location?
