Exhaust for hellion sleeper kit?
EgoBoost
9/11 Never Forget
2024 Black PP GT 6 SPEED
New ‘22 (non active) going Hellion sleeper kit. Don’t want to buy exhaust twice so need input on correct setup to reduce back pressure. Don’t want loud if I can avoid it. Any suggestions? Thanks
engineermike
La
2018 GTPP A10
Best advice I can give after a ton of testing and research is either a stock gt500 cat back ($1400) or for less backpressure a stainlessbros 2x3” resonator mated to a corsa touring axle back.
EgoBoost
EgoBoost
9/11 Never Forget
2020+ GT500 catback? That would be ideal actually since I’m putting a valance on as well. Thanks a lot!
engineermike
La
2018 GTPP A10
Yes. It may or may not work with tte
Gt valence but if you’re swapping then that part wouldn’t matter. The only remaining issue is that the connection at the front isn’t the stock 2.25”. I am told it’s 2.75” like the rest of the gt500 exhaust.
Zrussian13
Phoenix
I went with borla s type but it was still loud AF. I ended up cutting in a couple bullet mufflers by the xpipe. Still loud but much more Bearable. Sounds good too. Gets a lot of compliments. If I was doing it again I'd probably try the stainless bros resonator instead of the bullets.
wazslow
PA
2016 Mustang GT/CS
Although I'm not sure it's still an option, I have the loud valve boost actuated cutouts on mine with a Gibson catback. The catback was on the car when I purchased it. It screams when those loudvalves open up! Fairly tame otherwise.
Zrussian13
Phoenix
Unless things changed in the last year, no they are not. I planned on running those with stock exhaust bur had to change my plans last minute.
