Genxer
I added a heat shield a while back to help keep radiator wash out of my PMAS CAI. I mocked it up with cardboard first and then made it from two pieces, riveting together. Later I will post a pic of the part I added on top of the intake tube itself to control heat, but it's akin to the little foam piece that JLTs use. Overall, I think both pieces work together well to get the most out of the added flow of the PMAS. The PMAS guys mentioned that any time they tried to snorkel their intake it would cut down flow, so I decided the best way to get the best air temp along with flow this was to simply provide a large pathway for air to come in, while cutting down on hot air in the main stream of air being sucked in. My PMAS box has an enlarged opening on the front, that I cut. Without a snorkel, this can pull air from the grille, as well as the wheel well. Yes, a little hot air gets in from other places, but this is about eliminating some of the biggest contributors to heat while not limiting flow.
The air filter assembly is not on here, and neither is the radiator cover, which hides a great deal of the metal shield when installed.The shield is slipped in alongside the remains of the OE snorkel and goes back all the way to the plastic intake box. The tab is attached to the radiator support.
This is the sheet metal part with the mounting tab.
