GT500 Valve Cover Install
Niteghost
Mississippi
2017 S550 GT
Easiest fix is to buy and instal the sensor. It's about $30. Another option is to tap and insert a pipe plug. Third option is to measure the hole and find and tap in an appropriately sized galley plug.
Im going this route. I ordered a sensor this morning.
CowboyJohn
East Texas
2024 F150 STX Offroad, 2015 Mustang GT 5.0
Good to know on the sensor.
snipes
NY
2017 Mustang GT
Does anyone know what the function of the supplied pink plugs that are located on the underside? Is this just for shipping reasons?
drought_buster
Michigan
2017 GT350
I've always heard them called "rain shower plugs". I've seen vendors use them to regulate oil dripping onto valvetrain components. Ford uses them to drain the oil from behind the metal PCV baffle plate. The 3th one on the passenger side cover, when installed, will allow the GT500 air/oil separator to drain the captured oil back into engine.
snipes
NY
2017 Mustang GT
I've always heard them called "rain shower plugs". I've seen vendors use them to regulate oil dripping onto valvetrain components. Ford uses them to drain the oil from behind the metal PCV baffle plate. The 3th one on the passenger side cover is for the GT500 air/oil separator, if you remove the bolt that is torque in the cover.
So i should leave them alone and install as is? Thanks for the help.
luc
2017 GT with PP
They are 1 way silicone drain valve for the oil that get separated from the oil mist in the breather baffles
Do not remove them
I
526 HRSE
2017 GT350 Grabber Blue
What is the purpose for this install?
jloshotz
NY
Jack
2016 GT Premium
1) Way cooler looking than garbage plastic
2) Practically twice the mounting bolts thus way less likelihood of loosening and oil seepage (BEST reason hands down)
3) Arguably either hotter or cooler dissapation wise (many arguments either way)
4) Definitely heavier, i’ll take that negligible trade off
5) No need to lug around that pesky extra $350 😁
IMHO just a matter of taste otherwise
CowboyJohn
East Texas
Yep, from my experience and research the stock plastic covers only use 9 of the 14 mounting holes and they start to leak. The one I did for my son leaked pretty good.
The stock replacements also only use the 9 of the 14 mounting holes and are pretty close cost wise the the aluminum ones.
Paul McWhiskey
United States
Paul
2017 Mustang GT Premium w/PP
You forgot
6.) Its my car and I do with it what I want.
I would also include that it might be best as #1 instead of #6.
However, I am in total agreement with everything that you listed.
526 HRSE
You guys forgot #7...quality time in the garage with my favorite gearhead!
You should have her change the blinker fluid so you can spend more time with her.
