machsmith
- Mar 5, 2016
- somewhere along the river
- Jim
- Honda Minis
Thanks a lot for sharing the write up!!
Great work!
Great work!
Don't worry about doing it at 1K, Ford tells you to do it at 10K, so no worries there. I'll be doing mine at 750 miles.This is great!
Question, I was planning on doing the oil change at 500 miles, is it okay to wait at 1k? I will get to that mileage pretty quick because its my daily![]()
I can double-check tonight but I believe I saw someone mention before it was T6. I'll confirm this evening.Great write up OP, waiting on my oil/filter to come in from white bear lake this week. Doing mine at ~550 miles. Perfect timing and good tips. Do you know what size torx bit it is to get the door off?
I was worried about that as well. I just lifted the other side slowly and kept an eye on it. A couple of members said they lift in stages with the jack rails so that's what I tried. I lifted the first side and put it on stands in a low position. Then I lifted the other side slowly and put it on stands in a higher position. Then back to the original side to lift it slowly and increase the stand height to match the other side.I'm at 960 miles now myself, definitely need to get this done in the next week or so...great pictures by the way! Any issues with jacking the other side of the car while one side sits on the jackstands? I guess I'd be worried about the jackstands shooting out or sliding away as I'm jacking up the other side for some reason.
Use ramps if you think jackstands are not stable.I'm at 960 miles now myself, definitely need to get this done in the next week or so...great pictures by the way! Any issues with jacking the other side of the car while one side sits on the jackstands? I guess I'd be worried about the jackstands shooting out or sliding away as I'm jacking up the other side for some reason.
I always make sure that the floor jack is lined up so that the wheels can roll as easily as possible to prevent the car from being pushed forward or back on the jack stands. If jacking from the side this means that the jack is perpendicular to the length of the car.I'm at 960 miles now myself, definitely need to get this done in the next week or so...great pictures by the way! Any issues with jacking the other side of the car while one side sits on the jackstands? I guess I'd be worried about the jackstands shooting out or sliding away as I'm jacking up the other side for some reason.
I think 960 miles might be a bit too early to change. I would drive till at least 2000 miles making sure everything is worn in so you don't contaminate new oil with fresh metal shavings.I'm at 960 miles now myself, definitely need to get this done in the next week or so...great pictures by the way! Any issues with jacking the other side of the car while one side sits on the jackstands? I guess I'd be worried about the jackstands shooting out or sliding away as I'm jacking up the other side for some reason.
