Both are correct. The "Cartridge" is the filter element. The "Canister" is the plastic housing that encloses the filter.Just thought I'd point out that the filter in the OP's post is what's commonly referred to as a "Cartridge Style" not Canister.
oil filter 27mm socket
Zoro tools $5 shipping 4 choices
https://www.zoro.com/search?q=oil+filter+socket+27mm
a 1/2" 27mm deep socket is fine. It is what I used.will a 1/2" deep socket 27mm do the job like this one: https://www.harborfreight.com/12-in-drive-27mm-deep-impact-socket-67790.html
or do i need a short one as listed below?
Thanks to both for write up. One question. Why a 12 point 27mm socket rather than 6 point?
Since this thread is live again and no one has mentioned it, I use a Form A Funnel under the filter which sends the oil out to the wheel well where I put my catch can. Don't spill a drop and don't even need to remove the little door under the filter. The whole thing is done from the wheel well.a 1/2" 27mm deep socket is fine. It is what I used.
As has been noted, the oil will make a mess if you do not have something to get it to flow to where you want it. Rest is easy.
got a link to the one that fits perfectly? i am seeing various kinds on amazon. i'm close to doing my 1st oil change and i think this is going to be the messiest part.Since this thread is live again and no one has mentioned it, I use a Form A Funnel under the filter which sends the oil out to the wheel well where I put my catch can. Don't spill a drop and don't even need to remove the little door under the filter. The whole thing is done from the wheel well.
<TED>
I really don't. I bought it years and years ago to use on my truck. However, it is 15" long (which I think is the critical dimension), though anything over say 12" would probably work fine. Mine is the PIG brand. (New Pig is a company that sells a lot of garage products including absorbent mats to absorb oil which I use when doing oil changes - among other things).got a link to the one that fits perfectly? i am seeing various kinds on amazon. i'm close to doing my 1st oil change and i think this is going to be the messiest part.
https://www.amazon.com/Form-Funnel-Flexible-Draining-Tool/dp/B010BZ26EQ
I looked around for one at the local auto stores here but no luck. So I had to improvise with card board. Didn't spill a drop either. The key for me was turn the filter slowly and let the oil start to dribble out. Once dribble then turn it some more to let slowly pour out. The card board has to be in place and moved where needed of course. That was nothing compared to the shock of a sustained pour of oil from the drain plug. Thought I was going to have serious overflow issues. Next time I'll leave the oil cap on when draining to see if that slows it down.Since this thread is live again and no one has mentioned it, I use a Form A Funnel under the filter which sends the oil out to the wheel well where I put my catch can. Don't spill a drop and don't even need to remove the little door under the filter. The whole thing is done from the wheel well.
<TED>
Just ordered the red one you recommended.I really don't. I bought it years and years ago to use on my truck. However, it is 15" long (which I think is the critical dimension), though anything over say 12" would probably work fine. Mine is the PIG brand. (New Pig is a company that sells a lot of garage products including absorbent mats to absorb oil which I use when doing oil changes - among other things).
I hope this helps!
<TED>
