Fuel recommendations / octane booster
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
FCB & Earl: Thanks for the info.
FCB: Another stupid question...what's a BAP? I THINK I get the "volume" part of the equation that you mentioned. But can you give me an example of the ratio of something like MS109 in your G5 or what you think it might be with the G6? That is, a quarter of a tank? Half?
Earl: Not that I care so much about gas mileage but that graphic definitely shows how much more inefficient it is than regular. But, I see the price/gal reflects that inefficiency. I have honestly never been to a station that has it but they're around.
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
Kent, BAP stands for Boost-A-Pump
V00D00
Dover DE
2020 GT500
V and Earl: Thanks for the insight but I'm curious about E85 requiring 33 percent more fuel. Is the trade off more horsepower?
Yes, so to get equal power, 30% more fuel. So the lines pumps and injectors have to have room to flow more volume.
V: Thanks for the great advice. What mix ratio do you recommend? (5 gallons and top off with 91?) Also, what’s the shelf life? Is it better to buy it in 5 gallon or 30 gallon quantities?
I cant tell you off my head, but there are o line calculators to find out
V: My own thanks for that valuable tip and of course, as a "waxer," <chuckling> I didn't know what MS109 was. Now I do.
93 is still readily available in South Texas so I too am interested in your recommendation on ratios. In my case, simple, hard, street driving using 93.
For less than twenty bones per gallon, if the ratio is decent, that wouldn't be THAT much more in fuel costs. But, like Big John, I wonder about the life longevity when buying five gallons.
Thanks in advance...
In TX and with 93 available, id suggest water/methanol injection. Much cheaper and benefits go directly toward what you specifically need to fight, heat
kilobravo
Corpus Christi, TX
kilobravo.com
KB
V: First I've heard of that in a street car and it makes me think of the old days when the rail guys started using methanol. Is this mod complicated? Expensive? Easy to maintain? But obviously, my E85 questions have opened a Pandora's box. :-)
Deviruchi
VA
2020 GT500 (L0646)
Did I miss a memo? 91 should be fine for this car, it's sold nationwide after all and there are entire states like California where only 91 is available. Can the engine even tell the difference between 93 and 91? Does it have a sensor/timing adjustment capability?
Big John
Big John
Tulsa Oklahoma
2020 GT500 CFTP
V: Thanks again, I should have realized there were octane calculators online. Looks like you get a two point bump for every 3 gallons of MS 109 added.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
John: Thanks for that. I went to the site and did essentially the same calculation but I have 93 available. The results were nearly identical to yours and it clearly points out the fact that you need quite a bit of aftermarket fuel to achieve these final octane results. Not something I want to do with every tank of gas. Maybe V's suggestion to use water/methanol is a better solution, no pun intended. :-)
V00D00
Dover DE
2020 GT500
Quality parts go a long way.
Progressive methanol controller ( allows for ramping up spray amount based on boost pressure ie 10% @4psi, 100%@ 10 psi, high/low flow situations etc)
2.5g or larger tank
Pump
Lines
Fittings
The controller probably costs as much as the entire rest of items. Probably $700 total i think, its been a while since I've bought parts
Easiest way for a beginner is to buy a kit. Guys like me can save $ by piecing together
I dont suggest doing water injection if doing e85, its not wrong, but pointless, to me
kilobravo
Corpus Christi, TX
kilobravo.com
KB
Once again, most excellent advice, V...many thanks. While I used to rebuild my own Chevy and MOPAR motors, these days, "kits" suit me just fine. :-) Obviously, there's no room for the tank up front so does it go in the trunk like a nitrous rig?
Edit: OMT...can a system like this be used "on demand?"
V00D00
Dover DE
2020 GT500
You can mount different size tanks in different places. I believe someone already has a hidden tank available for the regular mustangs.
Methanol is highly flammable, which is why people usually dont run above 50/50 water meth. It burns clear so you would never know. You can run straight distilled water, or windshield washer fluid, which is 70/30 water meth, and has a blue colored tint, making it easy to see any leaks
You can set it up anyway you want, if you have a shop do it.
To me, if you want it on demand, you would still get a controller to spray progressive, and then an additional switch to turn that controller on/off at will.
It seems the car as upfitter switches already so should be easy.
Scenario would be switch off, you get nothing, controller is off, no spray at all.
Switch on, controller has power and sprays % at the preset values
kilobravo
Corpus Christi, TX
kilobravo.com
KB
V: Wow, that's a TON of info, THANKS but I wondered about the fire hazard, now I know. Definitely too risky for this old geezer so I guess I'll have to live with MS109 or Sunoco's product. Who's old enough to remember Sunoco's "Dial an Octane?" :-) My teenage hot rod would only run on Sunoco 260 and it ran HOT.
V00D00
Dover DE
2020 GT500
WW fluid is extremely safe, and again, straight water will add octane ( water cant combust) and cooling benefits. After initial purchase cost, will be much cheaper over the life of the car
Snoopy49
Earl
2013 GT500 - SOLD and 2020 GT500 - SOLD
Methanol is highly flammable, which is why people usually don't run above 50/50 water meth. It burns clear so you would never know. You can run straight distilled water, or windshield washer fluid, which is 70/30 water meth, and has a blue colored tint, making it easy to see any leaks
The reason people use methanol is because it is less flammable than gasoline. The flash point for gasoline is -45º F, the flash point of Methanol is 51º F.
The flash point of a chemical substance is the lowest temperature where enough fluid can evaporate to form a combustible concentration of gas.
