Fuel pump replacement on stock basket
Coyotebawl
Lafayette, Louisiana
2019 Mustang gt
Is it possible to just replace the actual stock fuel pump with a oem replacement without having to purchase a whole new basket ? I can't seem to find anything online, but was curious since I plan on running my stock one with a BAP and if it dies I would like the option of just replacing just the actual fuel pump instead of buying a whole new oem basket .
SnowFox
Mn
Grabber
2022 GT, 2017 ECOboost, Saleen S351
HKusp
Hampton, Md.
Jason
I know this is a DW400 video, but it's almost identical as far as the process.
Coyotebawl
Coyotebawl
2019 Mustang gt
I was speaking more to replacing the OEM fuel pump itself . I can't seem to find the actual oem fuel pump by itself as a replacement, all I'm finding online is the whole assembly / basket . Was hoping they sell just the pump. If so anyone care to share the PN# ?
Grimreaper
Dallas
2017 GT
Pumps aren't marked in the baskets. At least not with any part number.
Dw400 or other check valved drop in will do.
Would personally recommend a 10ga feed from fuse box to fpdm connector. 29-30 amps is common on the dw400 with booster.
Coyotebawl
Coyotebawl
2019 Mustang gt
Thanks for the wire upgrade suggestion I will have to look into that some more.
I am aware of the DW400 as a replacement but was looking for oem if possible but it's looking like that's not a option unless you buy the whole assembly. I was hoping I could change just the pump itself with another oem one .
Thanks everyone I will just pick up a DW400 and look into a wire upgrade moving forward .
NGOT8R
Adrian
2019 Bullitt
https://www.mustang6g.com/forums/threads/suspected-bad-fuel-pump-2019-bullitt-on-e85.189945/
beefcake
Bethel
2018 Ford Mustang
the kpm has a nice dual setup that is oem bucket style,
https://www.beefcakeracing.com/kpmmus1000-p/
we also have the li tuning twin setup as well
https://www.beefcakeracing.com/lituning-fuel-return/
both are budget friendly setups
Feel Free to DM me or call with any questions.
Terry "Beefcake" Reeves
Office - 855-TBR-RACE - Cell 513-478-1965
Owner Team Beefcake - 20+ Years Experience
Deal Directly with the boss, no pushy sales guys!!!!!!!
https://www.beefcakeracing.com - Your Forced Induction Specialists
#beefcakeracing #teambeefcake
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
You can't, they only sell pumps as an assembly for a while now. That's why dw400 is being recommended
Coyotebawl
Coyotebawl
2019 Mustang gt
I went with the DW400 and will run it @
18v with the BAP . I'll be on 93 0ctane so that should fit the bill
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
I believe on GT's the fuel filter is build into the bucket system, So it could be a slight benefit to get the new bucket along with the pump assembly.
Coyotebawl
Coyotebawl
2019 Mustang gt
The problem with that is alot of them don't have the ventiri port like the stock pump . The DW400 is the only one I could find since it was designed to work with the oem basket. I was looking for a OEM replacement drop in pump for the durability/ longevity , but ended up purchasing the DW400 drop in since options were limited which should work out anyway since it can handle 18v on the BAP ill be using .
Take the OEM assembly apart, and match the pump up with one of the aftermarket offerings. Ford didn't make the pump. Bosch, Walbro, etc. did.
https://walbrofuelpumps.com/255lph-walbro-gss342-intank-fuel-pump.html.html
NGOT8R
Adrian
2019 Bullitt
Did you make sure you got one with a check valve in it,or do you plan to install an external one?
Coyotebawl
Coyotebawl
2019 Mustang gt
I actually haven't received it yet I bought it from a member on here . I sent DW the lot number that was on the box and they confirmed it was from a batch that was made this year so it should have one ,but I will confirm once I receive it .
