Fuel filter underhood
SheepDog
Colorado
Dax
True. That was the first one I found.
like I was saying earlier, if you go with AN fittings and PTFE line, you can put the filter anywhere in the engine bay that it will fit, so you aren't limited to trying to squeeze it in between the firewall and the fuel rail section.
I have this fuel filter, with the 6 micron Microglass element. You can get a clamp with mounting holes and put it anywhere you want.
https://www.amazon.com/EVIL-ENERGY-...ffc5b5f3940a1900f00240b595d&gad_source=1&th=1
2016 Mustang GT PP w/ Voodoo
This is Ford's solution. The entire line with filter and bracket is $230. I bought one but I'm procrastinating on pulling the tank.
And the Filter is common to many other vehicles so it's readily available when its time for a new one.
Dude, I’ve been looking for that fuel line and bracket parts! Havent had any luck tracking those down. Can you help me with a link and/part numbers? Im switching a GT to a GT350 drivetrain. I have the tank parts but I dont think I have the line/filter bracket.
sms2022
Detroit
SS
2022 Mustang GT PP1 premium
Pretty
Completely doable once you start looking at using PTFE line and AN fittings. If you are using the factory fuel system, you can get the 3/8" quick connect to -6an fittings for the hard line on the firewall and the fuel rail, and then run PTFE line anywhere in the engine bay you want so that the fuel filter is easy to get to, and away from the exhaust manifolds.
https://www.summitracing.com/parts/...u_sqs0ZGHMS0gjXmvDRCIHqxa3ynyGPxoCJPUQAvD_BwE
https://www.beefcakeracing.com/radi...dJZSpJaHYe3whgwc2X4DZtx9cS9G48ZBoCaVQQAvD_BwE
https://www.racetronix.biz/p/adapter-10-orb-male-6-an-male-al-bk/adf-495113
https://www.summitracing.com/parts/...wqtfbsyTJmap1XmGIUv2_Em_7Rvt8YIBoCBEgQAvD_BwE
https://www.racetronix.biz/p/-6-hose-teflon-conductive-ss-black/tft1170-06b
Yep this is exactly what I did but to run a flex fuel sensor. Check my pcmtec flex thread for other part numbers also and a pic. I looked into running a filter but decided it wasn’t worth it as someone told me the factory filter is excellent
Torinate
Torinate
Ontario
2016 GT Convertible
This is the union where I was thinking.
DougS550
Fishers, Indiana
Doug
Hello.
Has anyone put in a fuel filter in the engine bay? Bad idea?
I have the Edelbrock SC and there’s the braided line going to the fuel rails. Thought about putting one between the junction of the braided line and the rails. Would need a female end male end filter to basically put it in plug and play. Anything like that out there?
Thanks!
Take picture. What - ORB goes into your fuel rail?
What - an line size?
Torinate
Torinate
Ontario
2016 GT Convertible
The pic I just posted is where I’d like to fit it if possible. Not sure of the size. It has the typical ford “push in” type clip.
Is this a 3/8” line?
illtal
I agree about the extra place for a fuel leak. There’s already enough places. But, for ease of getting to it to change it and easy installation, it may be answer for a plug and play type filter. I’m going to have a look and see what’s out there.
Put a dry quick disconnect fitting on either side, you will never have a mess when changing out the filters
illtal
I believe it is a 5/16 line on the 15-17 and a 3/8 line on the 18+ cars.
The disconnects should be fit for that
Torinate
Torinate
Ontario
2016 GT Convertible
Crap. Well, I ordered a bunch of 3/8” fittings so ill see what fits when they come.
