Where to mount fuel system filter
kcc0521
Falls Church VA
Bo
2015 Black GT PP
Has anyone mounted their fuel system filter and or Y-block anywhere other than under my car? I mounted mine under the car but i was wondering if the filter and or Y-block will fit in the inner fender behind the cover.
tsloms
Wisconsin
2016 Mustang GT Magnetic PP
It’s actually pretty cozy behind that inner fender cover and brace. The lines barely run through there clean. Under the car seems to be the simplest solution.
Kona 18
2018 Mustang
You can mount it anywhere before you Y block including the Y block inlet itself.
kcc0521
Falls Church VA
Bo
2015 Black GT PP
I know it can be mounted anywhere but I am curious if anyone mounted it in the fender well or engine bay. I don't think it will fit but figured I would see what locations others have used.
esacteksab
CO & KS
2015 Mustang GT
That looks great. Do you run hard line all the way to the tank?
There is soft line from the hat to this hard line. Hard line runs under the length of the car inside the front driver's side fender well. Then soft line to a Y that feeds both rails, then into the regulator, then returns using the factory line.
