Front end links bad. Best alternative?
DroopyGT350
Atlanta
Damien
2017 GT350
Mine went bad yesterday at 44k miles. Oem looks weak. Best alternative at a reasonable price? Also, I shouldn’t need an alignment, right?
DroopyGT350
Atlanta
Damien
2017 GT350
How did you tell they went bad?
Slight increase in noise over uneven surfaces over time, but yesterday the car started making much louder noises over pavement transitions and uneven pavement. Friend of mine is a tech and after turning the wheel he grabbed the link and held it tight while I rocked the car and the sound went away.
luc
CA
2017 GT with PP
Did you try to tighten them? If they get loose, even just a little bit, they get very noisy
DroopyGT350
Atlanta
Damien
2017 GT350
Is it that simple? Not being sarcastic. Never had a end link go loose.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
85 ft/lbs on the end link nuts. If loose they will pop and make you think the front end is going to fall off.
DroopyGT350
Atlanta
Damien
2017 GT350
That’s what it sounds like. And since it was so sudden I think they are loose.
K4fxd
NKY
If they are stock and you like to corner you will bend them. I like Steeda's adjustable end links.
Biggsy
MD
Warren
'17 GT PP, '10 Tundra
Most likely loose. Can retighten them and add some blue loctite. I have Whiteline end links but a BMR front bar. If you actually bent them then yea you should upgrade.
galaxy
St Louis
'17 GT350
The Steeda's are nice kit. I swapped to those when I found a bent one on an otherwise bone stock suspension car.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
Rock Auto sells a nice Moog replacement, steel and greaseable. Cheap too.
DroopyGT350
Atlanta
Damien
2017 GT350
Anyone know if a place in Atlanta I can pick up some links?
K4fxd
NKY
