Failed inspection.
XakwardX
Virginia
Kyle
2021 gt magnetic grey
You do not have to get an emission test in Hampton, he has the misfortune of living in N Va. You would be fine.
im more worried about the yearly inspection. I just moved here so I don’t know what to expect. if they look for check engine lights or cats or not
2016S550
Shopping
Check engine light has no bearing in Hampton, they are 99% not going under your car in Hampton Roads. Loud Mustangs are a dime a dozen around here. Do you have any cats at all?
XakwardX
Virginia
Kyle
I haven’t bought anything yet until I found out if I was good or not but I was going to go catted anyway since catless are hard to find.
Cobra2591
Cobra2591
Virginia
2017 Ford Mustang GT premium.
Tuner has had my car for almost 2 weeks and still hasn’t been able to tune it to where it will pass inspection. He’s been driving it and still can’t get all the sensors to come on. Didn’t think modding would be such a dam headache.
FreePenguin
Ohio
Donald
17 mustang
Unfortunately it can be, even small things can become a hassle.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Congrats to him for having a free ride for 2 weeks. Tell him just to flash in the damn stock tune. Check to make sure the o2 are functional, then do fords readiness procedure.
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
The O2 readiness has to go through certain steps to get them to go green. You have to drive for 15-20 minutes without large throttle inputs. Get on the freeway and drive no more than 55mph with no large throttle inputs. I reset my my readiness codes and withiin one day of driving I was all green again. Do you have a MIL light for no cats? If you don't its the way he is driving it to get the 02 sensors to go green.
Dave2013M3
El Segundo,Ca
This...
Prequisites: Cold Start, Fuel level between 15% and 85%. All accessories off
Start the vehicle and idle for 4 minutes.
Idle the vehicle in Drive for 1 minute.
Drive towards an empty street or highway, and accelerate to 45 mph slowly. Stay in second gear for 5 seconds during this acceleration. Get to the 5th gear.
Maintain a 45 mph speed for 30 seconds
Stop the vehicle.
Drive at 25 mph and drive for 15 minutes at speeds between 15-35 mph. Within this time, stop at least 5 times, and have at least 3 periods of steady speed for 90 second durations.
Drive the vehicle between 45-60mph for 8 minutes.
Maintain a steady speed between 45-60mph for 5 minutes.
Stop the vehicle and idle for 40 seconds.
Zelek
Hutto, TX
2021 Mustang Mach 1
You need to be able to flash back to the stock tune. Otherwise, you're screwed if you can't pass the O2 readiness. All of this "Just run through the drive cycles" will just waste your gas.
bankyf
Fredericksburg, Virginia
2022 GT500 CFTP
This...
Stop the vehicle.
As a certified emissions repair technician who regularly has to drive cars for monitors, I have found these procedures mostly worthless and a waste of time. Regardless of what you do, some vehicles get monitors really quick and some do not. I have one set within the first mile, and the longest one I have had is 500 miles. That's typically just to get all your basics including O2 and Cat. EVAP almost always takes significantly longer.
Zrussian13
Phoenix
This is spot on with how my monitors went green. After my twins install everything was green first day except evap. Took 4-5 days before that went green and I was averaging about 100 miles per day.
Dave2013M3
El Segundo,Ca
My car mainly went green other than EVAP with the first drive.
bankyf
2022 GT500 CFTP
Wait a second…. You have twins with cats and got all of the monitors?
Dave2013M3
El Segundo,Ca
The EVAP has to be done with less than 3/4 of a tank of gas and more than a 1/4 and it just takes a couple of drive cycles with some idling.
