Fluidyne warning: failed welds
Coastal-Mach
Wilmington, NC
Anthony
2023 BMW M440i, 2026 GMC Denali, 2021 Jeep JK
I had the same problem with Fluidyne, I purchased one for my Jeep through Summit. It failed at 10 months, called Summit and they replaced it under their warranty after BS from Fluidyne. Customer service at Fluidyne is non-existent.
HKusp
Hampton, Md.
Jason
Another vote for Mishimoto. They are excellent and will even replace them if they are damaged in an accident. I have their transmission cooler in my Superduty. Their quality is top notch.
Kermitz
Vacaville CA
Seth
2019 Mustang GT PP1 300A M6
Been pretty impressed with DeWitts radiators. Everyone I’ve asked about them, had nothing but good things to say.
Which is why you should never ever be using straight tap water to fill your cooling system. Don't most engines require distilled water if you're mixing yourself?
Yes, you’re correct - distilled water is the recommendation. That’s also what I’ve always used, not tap. Didn’t matter though, the Fluidyne welds still failed.
Tap water contains minerals which can leave deposits in cooling passages/channels within an engine and even corrode the internals of radiators over time.
Angrey
Coral Gables
2016 GT350
Tap water isn't going to cause corrosion appreciably any faster. It's just going to cause scale and solids in the fluid piping galleys and channels.
What's more corrosive is heat, moisture and oxygen with no active chemical anti-corrosive agent (included in most anti-freeze formulations).
Running straight water is the most thermally efficient mix, but doesn't offer any boiling point elevation. Coyotes and Voodoos offer 1.5 bar of pressure before release, so straight water boils at 232F under 1.5 bar. If you don't add any anti-freeze, and coolant temps exceed that, it's going to smoke the motor shortly thereafter.
Adding anti-freeze both raises the boiling point and lowers the freezing point. However, it also degrades the thermal transfer.
A good medium is to mix 2 parts water to 1 part Motorcraft Yellow. At 33%, you get 90% of the boiling point elevation and only a small decrease in thermal transfer. It also helps mitigate corrosion and scale.
TeeLew
So Cal
Tim
In all fairness, anyone who is running these engines in anger should be nowhere near 230F, but the Mustang rad is undersized. If you go on track, temps will go to the moon. In a racing environment, 200*F is about the limit. By 225*, you've already pitched something (head gasket or whatever).
Angrey
Coral Gables
2016 GT350
I was seeing 200+ sitting in traffic, sometimes 2010+.
We've since adjusted the tune to run the fans high speed at lower temps and it's helping a ton to keep them back down.
If I was gonna run straight H20, I'd at least research and add a good anti-corrosive.
And most guys don't enjoy (or suffer) the hot weather I have in SFL year round, so they have to consider freezing as much as the other end. And motrcraft is EXPENSIVE now. So swapping out for different times of the year is feasible, but just another cost and it's not cheap anymore.
HKusp
Hampton, Md.
Jason
Hostil
IL
Randy
2015 Mustang GT
I'm also going with DeWitts!
