F-150 Manifold Testing/Journey
Dr.Pat
Fort Myers, FL
2017 Mustang GT
Intake installed. Drove around block. Little bit of a kick for sure. Feels pretty close to S+ mode but all the time. Gotta get creative with zip ties on the fuel rail foam. Weird not having an engine cover.
A+ so far.
Side note. Probably just my imagination but I also notice a bit of "sucking" sound coming from the front of the intake after the throttle body. Could not find a vacuum leak though. Vacuum leaves appear to be higher than what I noticed with stock. 19-20 mHg vs 17-18 mHg. I am not entirely certain that is a good thing. Anyone able to confirm?
How was the install? Is there a DIY that you followed?
Volstang
Knoxville, TN
Randy
2015 Mustang GT
Can't wait to get mine installed!
tampasnake
Tampa, Florida
Shelby GT350R
I got mine on today. I had to stop my test run on my road course I mean hill because it was raining. I have 295/35/20 nitto invo's and I broke them loose twice coming out of corners in 3rd gear at 40 mph.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
You guys using a new tune with your intakes or running them as is?
MasterCylinder
Fort Worth, Tx
(sold)17 GT
From a PM:
Boggus said:
Any steps you remember, anything stand out that proved to be difficult? I have mine sitting in the garage along with the sensor to plug the hole.
Thanks in advance.
Nope. Followed the LMR GT350 install almost exactly. Placed all the attachments that were on the GT manifold directly to the F150 one. Make sure you clean off and watch or plug the intake ports on the block as it is stupid easy for things to fall in there. Especially bits of shop towel. Undoing and reattaching the 2 white sensors and the wiring harness tags(?) on the back side of the intake were the biggest pain. Then as I previously stated in my post you gotta get creative with some zipties on the heater hoses and fual rail foam since the attach points for the holders are no longer there.
Took me a long time (4 hours?) only because I have never taken my mustang apart before. Thankfully it isn't like Chevy where they have hidden bolts.
And no tune for me right now.
kluke15
Reno, NV
Kenny
2017 Mustang GTPP
got my intake in the mail today. noticed one of the sensors on the back of the intake was broken off. cant seem to find a part number and idk what it is for. its the sensor in the pic with the yellow dot on it. any help or guidance would be greatly appreciated .
MasterCylinder
Fort Worth, Tx
(sold)17 GT
Guys, I will request that if you have a question about the install to ask it here instead of a PM. Other people will be and have been asking the same question as you, hence why I keep posting PM quotes. Most of the questions have been answers already in prior posts. I'm not trying to blow you guys off but it really is straight forward once you get rolling.
Dr.Pat said:
Hey man, glad to hear the IM swap is pretty straight foward. Where did you find the LMR install directions for the GT350 IM? I checked their website but didnt see it.
Do all the hoses and attachments from the stock manifold match up with where they go on the F150 manifold? My biggest worry is getting everything off and not knowing where to connect the hoses and other attachments.
Here is the LMR install video posted earlier in the thread.
From Late Model Restoration install of a pp3 manifold. This video helped me out alot. Of course there are some differences when installing the F150 vs the PP3.
I believe around the 10min mark they start explaining how to torque the bolts.
And yes. ALL of the hoses connected exactly. In-fact despite the video I was able to get away with only disconnecting some of those things as stated in the video. Like the actual intake. I only disconnected the noise tube from the intake and left it attached. The intake itself I left in place and removed only the top half leaving the filter and the bottom half connecting to the grill in place. Watch for how the connections are actually locked. Some of them are push some of them are pull then push. Don't force anything because you will break it. Again, all the parts will connect back pretty much exactly as you took them off. Same places and all. In fact when you get the GT manifold off just set them next to each other and transfer everything over. If it is on the F150 manifold when you bought it just take it off and use the part that is on the GT manifold.
MasterCylinder
Fort Worth, Tx
(sold)17 GT
Just use a torques bit and take the one off the GT manifold and put it on the F150 one. Its the same thing. Those 2 sensors that look free floating are for the white connectors at the back.
MasterCylinder
Fort Worth, Tx
(sold)17 GT
I went ahead and made a video... I TRIED to keep it short but I ramble. Sorry. Hope it helps.
[ame]
gameovergt
Kevin
Lake Asbury, FL (Jacksonville area).
Kevin
2022 Ford Mustang GT California Special (A10)
i would try this mod but can't find an affordable intake.
gameovergt
Kevin
Kevin
[email protected]
florida
Nick D
red gt auto
If I don't get my AC fixed to my satisfaction I'll have my new take off f150 manifold for sale if anyone's looking
gameovergt
Kevin
Kevin
Boggus
Cypress
16 Mustang GT PP
Master ..... after a few days of driving with the manifold, what are your thoughts.
