Exhaust selection not available after h pipe install
Sean_zx5.0
New Jersey
Sean
Kawasaki Zx6r
Hey,
Just had an h pipe install on my 2022 Mustang GT premium with active exhaust. Issue is after the install i get a warning that says “Exhaust selection not available” and it won’t let me change it out of normal mode. The auto place reset the system a few times and checked all the fuses but wasn’t able to find any issue. They also said the didn’t notice any wires or anything that could cause the issue when they did the swap. Anyone have a similar issue and know what the fix is? Appreciate any help
SheepDog
Colorado
Dax
Check around the valves and wiring harnesses. (Near the mufflers) I seem to remember seeing a post of a few people having issues with the wires chafing on a heatshield or something, so perhaps when those guys were futzing around with the exhaust, the connectors or wires were damaged.
YULQQKN4
New York
Stephen
2021 Mustang GT 401A 6 speed
Had my H Pipe installed 1 day after taking delivery....never an issue....gotta be a loose connection somewhere.
J2t_s550
U.S
Jimmy
Possibly a connection that was never re-connected? I dont have active, but from what it sounds like, deff a connection/wiring issue.
WD Pro
United Kingdom
Lime GT
They’ve butchered your right side wiring harness …
Its most likely happened due to them A) not dropping the rear section or B) inaccurate cutting.
WD :like:
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
daSNAK3
Cary, IL
Jake
2021 GT
Yup, check the harness on both sides but probably an issue with the passenger side. Either they did not reconnect them or it got pinched by the car is my guess.
CR151S
AZ
Blake
'20 GT PP M6
Had my right side (passenger) harness replaced due to this exact thing….
Sean_zx5.0
New Jersey
Sean
Kawasaki Zx6r
Good leads in this thread. I’m gonna head back there today and have them double check the wiring. Hopefully that’s it
CR151S
AZ
Blake
'20 GT PP M6
It’s a really easy thing to spot: the harness typically makes contact with what looks like a metal pinch weld just above the center exhaust tip on the passenger side.
Hopefully they stand behind their work!
kz
West Chester, OH
Mustangs & F150
You can look yourself without heading back there. I have replaced both harnesses (btw - they rub against pinch weld and would blow fuse 34 since it shorts the wires to the valves) and re-routed them using zip ties so they don't rub again.
Sean_zx5.0
New Jersey
Sean
Kawasaki Zx6r
Ayee guys so I checked it out mysef and found out the wire right above the muffler on the passenger side came unplugged. I plugged it back in and it’s good to go. Had to of become unplugged when they were working on it. Good looks on pointing in the right direction
dman918
Algonquin, IL
2018 Mustang GT Convertible
Glad you got it sorted out, and it was such a simple fix!
