Edelbrock E-Force Troubleshooting Manual
Patriot Six
Temecula, CA
2020 Mustang GT
93. They were fine with the FRPP that came with the kit just regapped, but I've already been running them a year so I figured I might as well switch to a fresh set.
That's interesting because I haven't touched my plugs and I've already made pulls up to 7500 rpm for Lund. The Edelbrock gap seems too wide to me as well.
Kona 18
2018 Mustang
I used the FRPP plugs that came with the kit, they are one step colder and were pre-gapped to .029", tossed them in "as is". It's been 12k miles and they haven't given me a single issue.
I'm seeing about 13/14psi with the 3" griptec
mikengail
Albuquerque, NM
2018 Mustang GT Premium Convertible A10
What boost do you guys with EB Stage 1’s see on the supplied pulley ( with stock manifolds and cats)
Mine is a stock Stage-1 kit on 91 with long tubes, h-pipe resonator delete, stock mufflers and no cats. 8.7lbs is the max that I see...
wsfrazier
Pittsburgh, PA
2019 GT PP1 M6 401a
Bought the 1050x injectors, now I need to shop fuel systems.
Anyone know the details on the fuel rails that come with 18-19 2650 kits? What size is the crossover, -6 or -8? Will the rail support a -8 return line?
Kona 18
2018 Mustang
Few places sell Edelbrock specific kits, the rails are ORB 6, you can run a 8AN return just fine, you can also run a 6AN return line as well on a dual pump system. I run a 6AN return with dual walbro 450s(F90000274)
rum_punch_ruby
Chicago suburbs
Supercharged 17 GT Premium, Performance Pack
What are the bosch/frpp plugs gapped at that came with the 2300 stage 1 kit? I'm sure that info is in the install paperwork but I don't have access to it at the moment.
Torinate
Ontario
2016 GT Convertible
I believe Kona said pre gapped at .029.
Having issues?
rum_punch_ruby
Chicago suburbs
Nope just trying to figure out if I need to regap them. Planning on keeping them if I can when adding my other bits, but if I have to remove them to regap I may as well get a set of the NGK.
Car still in storage until end of March so putting a plan together and trying to have everything I need by then.
Torinate
Ontario
2016 GT Convertible
Nice! Mine too lol.
What are your plans come spring?
Jobodizo
Jobodizo
Kentucky
2015 DIB GT
Mine (with a 2650 '15 kit, FRPP plugs) came pregapped to something like .042, and I had to take them down to the recommended size.
Kona 18
2018 Mustang
Mine were NGK/FRPP plugs, the iridium ones, not the old black one, the black ones aren't good from what I've been told, the p# on the ones I received is M-12405-M50A snd they came in pre-gapped at .029", but I'd still recommend checking the gap
Torinate
Ontario
2016 GT Convertible
DW95s, EB intake, 87mm TB, VMP BAP, ngauge, Lund tune. I got everything but the Lund tune just need to install
Nice!
Did Lund day they would tune the 87mm TB? I thought they’re not fans of them and won’t tune them? If they will, I’m going that route!
Let me know what they’ve said!!!
illtal
90
Nice!
They aren't fans of the BBK 90 mm TB. the 87 TB is the Bullitt Throttle body, I'm sure they can handle that. I'm going to put one on mine as well. they are like 188 dollars.
