The stage 2 uses a different routing apparently...Your top left idler looks different than mine. It also appears your belt is routed incorrectly.![]()
It was done by Ford, I'm sure it was done properly I just cant seem to figure out what is out of alignment. It seems like maybe the bracket isn't close enough to the block and the tensioner is too far away.Do you happen to know if the block was drilled from factory and/or the brass spacer was fitted?
(I’m assuming the stage 2 kit uses similar parts to the stage 1 up to a certain point)
Is it possible that the spacers got jacked up at step 43?It was done by Ford, I'm sure it was done properly I just cant seem to figure out what is out of alignment. It seems like maybe the bracket isn't close enough to the block and the tensioner is too far away.
The spacers were installed correctly, however I think I found the problem. The center top bolt on the bracket isn't seating flush with the engine block. It's possible that the casting was a tiny bit off or is slightly out of tolerance. This is causing the bracket to not be parallel with the block and is slightly angled so that the tensioner is further from the engine block than it should be.Is it possible that the spacers got jacked up at step 43?![]()
I havent gotten it fixed yet, but I havent gotten on it very hard since this issue first started.What worked?
That's extremely useful, I will do that. Thank you!I had the same issue across multiple engine long block/timing covers. I got the stock measurements and verified with a slide gauge the stand offs were correct length....I had to have them milled down to bring the plate into alignment with the blower pulley using a straight edge loaded from tensioner to blower pulley then blower pulley to water pump.and water pump to crank all where inline except the tensioner mounting bracket so I had them milled down and its tracking perfectly..
Just an FYI......
