E85 Tune with stock manifolds
JoeCee
Milwaukee
Joe
13 GT500
Has anyone had 02 sensor issues with e85 tune while using stock manifolds? I know people have issues with the non-angled o2s with long tubes.
Zrussian13
Phoenix
Ran e85 and stock manifolds for over 40k with no issues. Spent the last 50k running boostane through it turboed and still no issues with the stock o2s. Over 98k miles now and I'm still running the o2s from the factory.
ZeroTX
ZERO
2022 Mustang GT
What kind of power can you make with a naturally aspirated Gen3 Coyote through stock manifolds/cats on E85? Is there such thing as a flex tune? What if you're on a road trip and no E85 is available?
engineermike
La
2018 GTPP A10
Absolutely and it works especially well on the gen3. Unlike the gen2, the gen3 has the ability to float spark timing, max engine load, and dozens of other parameters as a function of learned ethanol. Now, whether your tuner will do it or not is another story.
robvas
MI
2011 GT
Then you fill up with 93 and switch back to your 93 tune
ZeroTX
ZERO
2022 Mustang GT
Isn't that risky mid-trip? Brick the ECM and you're 700 miles from home... Then what.
junits15
MA
Justin
2019 Mustang GT
If you go on a long road trip it would be prudent to not start on an ethanol only tune.
And you do not need special manifolds for e85, the stock O2 sensors and manifolds are not susceptible to any damage from e85.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
what manifolds ?
You drive a f-150 ?
HKusp
Hampton, Md.
Jason
It's pretty much IMPOSSIBLE to brick the PCM on these cars. @Rolls at PCMtec tried and they couldn't do it.
I Bleed Ford Blue
North East OHIO
I think he meant having something go sideways while your loading the tune and you end up with a no start/no run condition, not permanently damaging the PCM beyond repair.
To the OP, if your going on a long road trip, switch over to your 93 tune before you leave home, that way if something does happen, you're at home, not 200 miles from nowhere.
Pistol_91
Clearwater
2020 mustang GT
If your going on a long road trip, switch over to your 93 tune before you leave home, that way if something does happen, you're at home, not 200 miles from nowhere.
This type of thing used to be called common sense years ago.
