Dyno'd Whipple 2.9 tonight, mehhh.
torch2k
Canada
I've been getting the kinks worked out in my tune with Palm Beach Dyno. The drivability is pretty good overall, so I thought it was time to strap it down and see what kind of power it is making. FWIW, where I'm at in Canada I guess we run on pretty mediocre 91 gas.
Here's the spec on my car:
Whipple 2.9 gen 2 stage 2
132mm TB
3.75 pulley
56lb injectors
BAP
MAK Cat delete
Borla ATAK w/X-Pipe
This was my first time going to this local dyno. It was a pretty dumpy setup with an older Dynojet. It made what I feel is a disappointing 621whp / 469tq (corrected).
We did a second run later (no chart, sorry), using a different set of monitoring tools (OBD2 tool this time), and the A/F showed better AND smoother at around 11.8-12
The local tuner said I should ask for another 3.5-4% fuel on my map to run richer and accommodate the local 91 octane fuel and i'll make more power.
Anyway, that's my story. I'm definitely interested to hear your thoughts or suggestions if you have them. Cheers!
https://photos.app.goo.gl/NxNYWjxBPWBnvzzS7
TripleB
Idaho
2015 GT Snack Pack- Whipple Stage 2
Wait, the stage 2 Whipple comes with 73lb injectors ?!?
TripleB
Idaho
Also how high did they take it? Mine made 625 at 700 and 680 at 7500rpm
SVT-DADDY
World's heaviest S550
CT
2015 GT Convertible
It's showing time where I am used to seeing RPM but it looks like a short pull to me.
torch2k
torch2k
Canada
Sorry I should clarify. Bought stage 2 kit used (dual fans, 132mm TB) but without injectors. PBDyno sold me 56lbs. They said it would be enough with BAP and 91 octane / 3.75 pulley.
Dyno pull was to 7500rpm
SVT-DADDY
CT
2015 GT Convertible
You pull the fuse for traction control?
Clean tires?
What was your max timing under boost?
torch2k
torch2k
Canada
Photo of chart w/RPM instead of time
https://photos.app.goo.gl/TvpmAPF3DZwyHfjU7
Tires were sprayed liberally with belt dressing by the dyno tech. I didn't know it was a thing, but he swore by it (and they sounded extremely sticky).
I don't know for sure on the timing - I think I saw it go up as has as 17 degrees but didn't get any detail on that.
Didn't touch any fuses. Car was in normal driving mode with traction control turned off via toggle switch.
Burkey
Australia
I just pulled up a WOT datalog I did the other day, and it shows between 16 and 17.5 through the pull
Can you tell me at what rpm you started to see 16 degrees?
Edit: worked it out.
foff667
Clermont, FL
2014 Mustang GT Procharged D1X
dyno graph shows they made a pull to 5300 rpms lol
A. find a dyno made in the last 100 years or that isn't a complete pile of crap
B. Either your going to listen to PBD or you aren't, if you are then contact them, if you aren't and you are going to listen to "the local dyno tuner" then go to them and part ways with PBD otherwise honestly who cares what some local dude is saying if you aren't using them to tune with...
With all that said run it at the track, if it traps 130+ it won't matter what the dyno says.
torch2k
torch2k
Canada
I'm on board with listening to PBD - only went to a local dyno to see HP/TQ numbers. I made the post because the numbers were lower than I expected to see...
foff667
Clermont, FL
on a dyno that was wack
Torinate
Ontario
2016 GT Convertible
Where in Canada are you?
