Do I need any additives when adding distilled water?
intheairtonight
2018 GT
Replacing my thermostat- to replace the lost coolant, I'm going to use distilled water. Will I need any extra additives?
Madtel4
Kansas
Lee
21 MACH 1, HP 1064, 20 Ranger XLT & 20 Explorer ST
Yes 50/50 antifreeze.
Lee
stevegt
Bay Area, CA
2012 Mustang GT Premium. 2019 GT PP1 ordered
Use the premix 50/50 antifreeze or mix regular antifreeze 50/50 with distilled water.
intheairtonight
2018 GT
I'm not replacing all of the fluid, just the small amount that will spill. Do I still need 50/50? I can't just use straight distilled water?
TomcatDriver
Mojave Desert
2017 GT350 Magnetic w/black stripes
Ideally it would be 50/50. Get the right stuff, safest to just go to your Ford dealer and get a gallon of pre-mixed. If it is really just a small quantity (cup or two) distilled water will be fine.
Ford VC-3DIL-B Orange
intheairtonight
2018 GT
Gotcha- is the stuff at Ford different than the Motorcraft stuff at Walmart?
TomcatDriver
Mojave Desert
Nope, as long as you get the right stuff. Coolant can get weird. Some are comparable, some are not. Just get the appropriate Motorcraft stuff, there is more than one kind.
Southview
Viera, FL
Herby
2015 GT Premium Convertible
You are in Florida. Just fill with some distilled water. You will fine.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Florida.. I'd run 70%/30% Water/Coolant. JMO.
Nuked
Morgantown, WV
2016 Triple Yellow GTPP w/Recaros
This.
You will loose roughly 3 qts of fluid, just add distilled water to fill.
69mach1-395
central nm, usa
2016 RR GT/CS
Catch the drained fluid in a clean bucket and reuse it...
Joe 5.0
Bermuda Triangle
2015 Mustang GT/PP
Will I need any additives with the distilled water?
Read above. If you're in an area that doesn't get freezing weather, throw in some distilled water.
Or, just catch the coolant in a clean bucket and pour it back in.
