Cylinder 4 Down. Home Engine Rebuild Thread
Wengerd Performance
Gold Sponsor
Paris, Tn
wengerdperformance.com
Derel
18 GT Whipple 15 Mustang GT TT 18 F150 VMP ODIN
The tune was NOT the issue here.
A intake (larger diameter) simply requires calibration of the maf transfer...
Your car had a issue as we used our proven maf transfer data for your new intake and even added an additional 30 percent fueling to the maf and your car was still lean up to 30 percent on the fuel trims.
We advised you swap back to the other intake multiple times as there is a underlying issue.
We logged you back on the other intake and as we clearly told you the issue would go away and trims within 5 percent.
Running the car with 30-50% fuel trims is a asking for a disaster.
Running the the cylinder heads temps to 260 is also asking for failure.
We even verified this by sending you a stock tune with maf transfer data and LU47 data only and as you remember it has the same lean issue with that intake you installed.
Every other car with this intake has 0 issues.
We even sent you a stock tune with 130mm data and still had a lean condition when it should have been a rich condition .
No matter what tuner would have input the data for your maf transfer you would have had the same lean condition till the underlying issue is resolved.
A tune can not fix a mechanical issue/vacuum leaks or fueling issues.
You can easily view your datalogs and plot maf lb min against maf period and see you have a accurate maf transfer data and one that is even 30 percent high on maf data but still shows 30 percent lean trims
This was an issue not tuning related
tdstuart
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
We even verified this by sending you a stock tune with maf transfer data only and as you remember it has the same lean issue qity that intake you installed.
Never blamed it on bad tuning. Just said my tune was off, which it was, and I took the risk of running the car like that.
Not trying to say you guys messed up, just saying the car was fueling correcting a ton and I took the risk of running the car like that.
FreePenguin
Ohio
Donald
17 mustang
can't blame the guy for trying to defend his business. I am just being unbiased, but if someone said 'the tune blew engine' and diditn really specify the variable of stuff that could of gone wrong, me as a general reader would be like, man I'm not getting tuned there.
but since you guys got it all out in the air, and such. it sucks. hope the rebuild happens quickly and easy.
either way your car will end up being better than ever I'm sure! you are way ballsier than me. I would of had that thing parked entire time til it was perfected 100000%.
DougS550
Fishers, Indiana
Doug
Yeah no kidding. I don't think I've ever gone above 235° and if I start approaching 230° I get off the fun pedal. Heat is a big killer with these engines. Good luck with the build.
I'm surprised no one has come up with a program which you can set your max temperature where your engine will go limp mode untill sufficient cooling has been achieved. Same for low oil pressure, like max RPM limiter.
engineermike
La
2018 GTPP A10
Both are easily doable. They might even be set up already in the stock cal. I’ll have to check…
DougS550
Fishers, Indiana
Doug
For me it's a no brainer. Why would you not be able to set limits/perimeters which could save thousands in engine repairs.
tdstuart
tdstuart
Arizona
Triston
🦈 dun dun.... dun dun.... dun dun dun dun dun dun dun dun..... 🦈
Ya I just got annoyed that no matter what we did the car didn’t like the tune and intake. Said F it and ran the car anyway.
Im not gonna blame wengerd for my engine blowing, they stated that I should switch to my stock intake as the car was fuel correcting heavily. Maybe they couldn’t tune the intake right, maybe the intake is still leaking from somewhere, maybe the intake has a defect I can’t see, idk. But Im not gonna say that my engine blew because of them, was my choice to drive the car with the car fuel correcting so high.
I think I’ll switch tuners anyway. Not gonna start saying anything till I have some confirmation of what I believe, but overall the customer service isn’t what I want. Maybe it’s just me as a client, but I honestly feel like wengerd is always pissed at me and doesn’t want to talk. Maybe I’m just a bad client, but I work and deal with customers constantly so I feel like I should know what to expect and how to act.
Either way doesn’t matter much to the original point that wengerd didn’t blow my engine. The tune may have but that’s only cause I ran it even tho it was fuel correcting heavily.
engineermike
La
2018 GTPP A10
Ok, in the factory stock Mustang GT tune, there are rev limiters that come in lower as engine oil, engine coolant, and transmission oil temp increase. When engine coolant exceeds 244 deg F, the rev limiter starts coming down. By 260 F, it's only 3000 rpm. There's also a lower rev limiter for low oil pressure. And finally, there are spark timing reductions at high coolant temp and lean A/F but some tuners zero a lot of this stuff out to get the limits out of the way.
Zrussian13
Phoenix
Lunds treated me great for the last 3 years and multiple tune revisions when I added/ changed stuff. And I've never seen them trolling the forums. It's a win win.
DougS550
Fishers, Indiana
Doug
For me, when I install my SC system, I will make sure my tuner knows safety of engine, is my #1 factor. I always have fun but will never do shit which I know will grenade my engine. So when shit does break,I know it was from having to much fun, not bypassing engine safety. Thanks
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
If safety is your #1 factor, kiss pump gas goodbye haha
tdstuart
tdstuart
Arizona
Triston
I think if he sticks to 91/93 and doesn’t run a lot of boost he will be fine. But e85 and a good built in ethanol reader so he can read percentage real time would be the better option.
Yea, unmetered air and MAF systems don't like each other :)
Sometimes personalities clash. I don't get along with Jon at Lund, not sure if it was Jr or Sr. Back around 2014.
Anyway I will never use Lund.
I am not affiliated with Wengerd in any way.
tdstuart
tdstuart
Arizona
Triston
Who would you recommend?
And ya sometimes people clash, lots of people seem happy with wengerd so it’s obviously not everyone.
