Cylinder 8 down on compression and misfire
Pvklol17
Pavlo
2017 Ford Mustang GT
After taking a trip to Mexico I got a cylinder 8 misfire code and car did not run right. Pulled into a parking lot popped the hood and my air intake filter was covered in oil and the intake tube had a puddle of oil in as well so I limped it home. Next day I decided to do a compression test and every cylinder was at around 230-250psi except cylinder 8, it was at 60psi and that spark plug was covered in oil as well. Then I poured some oil into that cylinder and did a wet compression test and it was now reading 120psi so I know the rings are gone more than likely. The car is a 2017 gt with a vmp gen 3 blower 88mm pulley and on 93 pump gas tuned by lund. Anyone have any suggestions on what I should do to the engine at this point?
seth21w
Georgia
Seth
2016 Mustang GT base PP ingot silver
Did you happen to get gas while in mexico?
Lime1GT
Winnipeg, Mb. Ca.
Thomas
2017 Mustang GT PP
Anyway you look at it the cylinder has to be inspected to see if a block is needed. If you have access to a inspection camera you can look into the cylinder through a spark plug hole. That may help to guide you to whether the block is damaged or piston repair only before removing the engine.
EFI
Masshole central
5.Br0
Sounds like good ol' number 8 overheated. When you take the engine out, make sure to address this issue for future protection.
Jay-rod427
Kansas
2016 GT C/S
Good ole fashioned ring land delete kit!
onlyturbo
Long Island NY
Rony
2015 Mustang GT PP M6spd, 2016 Audi S4 (Sold)., 2009 Subaru STI (Sold), 2003 SAAB Aero (Sold)
Sorry to hear that!
Can you recall the exact last run condition your car was in (gear, rpm etc) before going WOT and having the failure?
If it is a ringland then major detonation had to occur somehow obviously.
Boosted21
Nj
Ethan
2021 mustang GT
just curious did you have an aftermarket thermostat like a 170 degree thermostat or stayed stock?
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Is this a boosted setup running gasoline on stock ring gaps?
Jackson1320
California
Jaxson
2015 mustang gt
you can build it or get a short block. a shortblock from a f150 is pretty cheap. you can get a gen3 shortblock for about $2500 new
AvalancheSVT
houston, tx
Douglas
2022 Mustang GT PP1 6spd
do you have the head cooling mod done?
Grimreaper
Dallas
2017 GT
88mm on the 2.65 rotor pack is 13 psi according to vmp. Seems like that's usually considered a bit much for pump 93 right?
The 2.3 is usually right at 10psi at 80mm which most accept as pump limit.
Threads old though but would like to know how much timing it was taking. Can't imagine any more than 14 or 15 degrees
