Check Engine Light On
KiLLeR2001
Orlando, FL
'89 240SX, '17 GT350
I've made it a habit to check the dipstick every 500 miles. So far so good, the level hasn't budged.
mustang1
Dallas, TX
what does the GT350 owner's manual say for checking engine oil ? My owners manual says to check every month. That's a little vague, but lets assume that means every 1000 miles. If a car is burning 1 quart every 500 miles, it will get 2 quarts low between checks. And many folks will assume their car can go 3000 miles without dropping a significant amount of oil.
shelby_r
shelby_r
San Antonio
2017 GT350R, 67 GT350, 68 GT350 Con, 65 R Restomod
Honestly, that's what I thought. I never imagined that the engine could burn so much oil in a short amount of time.
firestarter2
NYC
RR G350 Track
That seems to be alot.
How low can the oil be before the oil pick up is out of the oil? Before that being low isnt that big a deal.
Tank
9/11 - Never Forget
Above the Notches
G0853
I wouldn't worry about what the manual says about checking the oil. These are hand assembled motors with known suspicions about oil usage.
I check the dipstick at every fill up (as has been previously mentioned by other posters) and before start up if it's been sitting for over a week. I obsessively check the ground wherever I park. I also check the oil pressure guage regularly when driving- second nature for me now. All part of owning a GT350.
Good luck [MENTION=16199]shelby_r[/MENTION]:cheers:
shelby_r
shelby_r
San Antonio
I just talked to the dealership. They have a call into Ford to get a steer on next steps. And, they agreed with me that it isn't an oil leak, but most likely oil consumption.
We'll see what comes next!
rahtid
Phoenix
Jonathan
2017 Shelby GT350R
My check engine light came on at 1600 miles for bad thermostat.
Tank
9/11 - Never Forget
Above the Notches
G0853
Grrrr. Not good. Here to hoping this won't evolve into another engine replacement thread:cheers:
Again, good luck!
shelby_r
shelby_r
San Antonio
[MENTION=16199]shelby_r[/MENTION], any loss of power?... limp mode?
Nope - neither. Although, the engine sounded odd upon startup after the check engine light came on. But, once the engine was running, it sounded perfectly fine.
However, I only drove it to the dealership after noticing the light.
superman07
columbus ohio
2016 gt350
ford dealer didn't tighten my filter, lost 2 quarts went to dealer on a flatbed, never lost pressure, no engine light.
shelby_r
shelby_r
San Antonio
Just got an update from the dealership: Ford wants an oil consumption test completed.
So, they are going to change the oil and filter, mark the level, and then have me come back at certain mileage intervals to check the oil level.
...so far, sounds like good news. We'll see what the consumption looks like down the road...that could lead to bad news. Hopefully, not! :)
DrumReaper
South East
It's amazing the variance in these engines. Knock on wood, zero oil use here that I can tell of, but it seems to be a common issue.
Wblv17
older fart
Crazyville Texas
Rob
2014 5.7HEMI Ram and 2015 eco boost race red pp
like my Dad taught me, check oil in the engine and tire pressures at each gas fill up.
Good luck OP,
Essex Wire
LA
Shelby GT350 Tech Pkg
Do 2017s have the oil consumption issue as well?
