Check engine light flash while on track. Road america
Vettel-ish
Vettel-ish
Jefferson County WI
Andy
17 GT350 (SOLD) 11 5.0 TRACK 17 Explorer 16 Fusion
Update,
Dealership says they want to look at it but for now keep running it (I trust this dealership fyi) Mostly likely an electrical glitch.
I will dig around in the engine bay this weekend. Been to busy at work to look at it since we got home from Road america.
If anyone has anyplace to look I will gladly take your advice.
Silver Bullitt
Parkville, MO
2018 GT Coupe PP2
I had the P0300 code. This is a general misfire code not specific to any cylinder. Mine turned out to be a bad vacuum canister purge valve. Have you noticed any rough idling?
pilotgore
US
A bunch
Not the OP, but I’ve had my purge valve replaced twice (which caused a CEL, but the CEL stayed on.). Also the pigtail connector that connects the harness to the purge valve has been replaced. The connector has a plastic stent to help straighten the wires prior to entering the connector. With mine, the electrical tape thats over the stent and connector stretched, and rubbed one of the wires raw to the point of breakage.
Vettel-ish
Vettel-ish
Jefferson County WI
Andy
Not anymore than normal I guess. Car is going in next week to get sorted.
Vettel-ish
Vettel-ish
Jefferson County WI
Andy
I was at 18,600 miles and less than two months out of 3/36K and Ford wouldn’t cover it.
Lame!! I have an extended so I should be good...key word...should.
Silver Bullitt
Parkville, MO
2018 GT Coupe PP2
As an update, I appealed to Ford Customer Care that this is an emissions issue and should be covered by the 8/80K emissions warranty. They approved the repair on Ford’s dime.
km1075
Chicago
2018 C63s, 2020 GT350 HEP
For what it's worth, I was having the same issue with flashing check engine light and then light turns off. Last weekend it happened again, but this time the light stayed on. Dealer checked and I had the P0300 code. My dealer determined it to be a bad Mass Air Flow Sensor. Mass Air Flow Sensor | FordUS
