Cheapest Performance Pack Brake Kit?
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
Thinking about trying to track my car. I have a 2015 Mustang GT Premium Auto. Heard from lots of people to upgrade the brakes to those found on the performance pack before I attempt to track the car. I also like the idea of having better braking as I have even felt my brakes fade on the street.
What would be the cheapest route to upgrading the brakes to the 6 piston brembos?
I think all I need is the calipers, dust shield, new brake fluid lines, and new pads and rotors.
Rock Auto sells remanufactured pp calipers for ~$480. I can buy used ones for about ~$400 (although at that price I would rather buy new ones for $80 more).
I also think I found the right dust shields (Part #: 2K004), although ford sells them for $100+ and rock auto may have them for $15.
I think I also found the brake hose for $30 from ford.
Is there an easier or cheaper way to do this and do I have all the part numbers correct? I've also heard that buying parts made for the bullitt mustang may be cheaper.
Also what rotors and pads would you guys recommend for spirited street driving and maybe a track day if I ever do it. I've heard lots of people like drilled rotors more than drilled and slotted but is there a particular brand? And what should I get for pads? I'm not going for the cheapest rotors and pads, just the cheapest way to get the rest of it.
Rapid Red
Woodstock GA
Greg
Have a look here to see what is needed, required.
I Bleed Ford Blue
North East OHIO
You will need calipers, rotors, dust shields, hoses, crush washers, pads, pins and clips.
You can buy a complete kit from LMR with all new parts for 1K. By the time you piece everything together to do the swap correctly, you will have spent that much, if not more. Just buy the kit. And don't forget you will need at least 19" wheels and tires if you don't have them already.
BabyDoc1012
NC
‘23 Lighting XLT, ‘21 Expedition, ‘22 Mach 1
Anyone have opinions of the Bullit kit? Is it just the performance pack kit with red calipers?
paulm1
Northeast PA
pau
2021 GT mustang
Yeah, from what I can tell it's just red as the change. And I don't think the rear setup in the bullit kit is any increase in performance over the base GT, just red calipers and brackets, I may be wront though.
BabyDoc1012
NC
Yea looking at the kits on LMR it looks like the bullit, performance pack, and M1 are just a front upgrade over the standard GT with the bullit being the exception that it includes red rear calipers. I thought the M1 had better rears too?
I Bleed Ford Blue
North East OHIO
The ONLY difference between the PP , bullitt and M1 brakes is the color of the calipers.
luc
CA
2017 GT with PP
Stay away from drilled rotors if you ever intent to track your car
Get the cheapest blank rotors from rockauto. Either Centric or Wagner
tdstuart
tdstuart
Arizona
Triston
Why not drilled or slotted rotors?
luc
CA
2017 GT with PP
Slotted rotors are fine but you’re paying extra for something that serve no purpose
Used to be a time, like a very long time ago, when pads would be out gazing and therefore, at least the theory, the gas could escape through those slots
Pads don’t do that anymore
As for drilled, they are ok for light duty, such as on the street, but will develop cracks, going from holes to holes, on a race track
Even a plain rotor will develop cracks on the track but much later and smaller cracks than drilled rotors
Vicr
Fortuna Foothills, AZ
Vic
2015 Mustang Ecoboost Premium
You can get a full Brembo 6 piston front brake kit from Shelby America on eBay. I got my set for under 5 bills with shipping. They are new take offs and bolt right up.
shogun32
Northern VA
The cheapest package, rotors, red calipers, pads, 4 braided lines is $1200 from Steeda. All parts new.
DrZed
Canada
Cam
2021 Mustang GT PP1 M6
My understanding is the PP rear caliper is different, to allow for a slightly thicker brake pad.
