ORRadtech
- Sep 12, 2019
- Atlanta, Georgia
- Dave
- 18 Mustang EcoBoost convertible, 14 Ford Fusion SE
A few thoughts.I've just noticed something.
The instructions for my pressure bleeder state that I should not exceed 28 psi.
On the pressure indicator the red zone starts at 32 psi.
However, here's what the service manual says:
Why do they recommend such a high pressure? 20 psi worked just fine for me.
Does this have to do with the valves in the ABS module? Do you need higher pressures to open them up?
28 psi seems oddly specific.
They say not to exceed 28 psi out of concern for the vehicle, not the tool.
Cheaper to buy a guage off the shelf than have a special one made.
Ford says 30-50 psi, if they tell their service people it can go to 50 psi it probably has.
Seems to me the factory service manual should be the authority, not a random tool manufacturer.
If 20 psi worked for you, great. 5 or 10 would have worked too.
30+ would have been faster
Pressure bleeding does not bleed the ABS, regardless of pressure. You will have to use a scan tool with that function to bleed ABS.
Tha ABS module doesn't hold enough fluid to affect your flush.
