Torque values for caliper bleed screws?
matthewr87
2018 GT350
Does anyone have the torque values for the caliper bleed screws? I just noticed I have fluid leaking from the screws at all four corners. So I either undertightened them or overtightened them. I am using a tiny 2.5 inch wrench to hand tighten them so I am betting on undertightened. Thanks.
Lilbro
Phoenix, AZ
George
2019 Mustang GT Convertible & 2016 Expedition Limi
Bleeder to caliper
9mm screw - (5-8 ft-lbs)
11mm screw - (9-12 ft-lbs)
I searched a few sites and multiple sites say this.
JAJ
Vancouver BC
2016 GT350 Track Pack
The factory maintenance manual specifies 14 newton-meters or 124 inch-pounds for front caliper bleed screws and 11 newton-meters or 97 inch-pounds for the rear caliper bleed screws on a GT350. The torque settings are specific to the GT350 - other S550 brakes are higher or lower depending on which caliper it is.
matthewr87
matthewr87
2018 GT350
Thank you sir!
Bitten in '69
Round Hill, VA
Fred
19 GT350, 22 Ecoboost HPP, 90 GT, 82 GT
Before you drive yourself nuts on the torque. Do yourself the favor of checking the bleeder and the seat in the caliper itself. Either one could have a burr or debris causing the problem.
In your case, I doubt this is the issue since all four are doing it. But, if it persists...
