CFTP Wing
galaxy
St Louis
'17 GT350
I’m surprised that f$&@ still has a website or store front. I’m one of the guys that got screwed. Take it first hand…walk away. That whole organization is a piece of shit.
Ended up getting an Anderson. The only difference from the Anderson and factory is the patented drain holes (absent on the Anderson) and the forged carbon pedestal mounts (not the pedestals themselves, just the part of the wing that bolts to them). The Anderson mounts are weaved carbon like the rest of the wing.
* I didn’t leave both number plates on the rear…had both on while deciding which one I liked best.
Epiphany
Global
I like to disassemble things.
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
galaxy
St Louis
'17 GT350
@Epiphany isnt that a vent to equalize the pressure inside the wing more so than it is a drain hole? There’s no reason there should be water inside that needs draining.
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
@Epiphany isnt that a vent to equalize the pressure inside the wing more so than it is a drain hole? There’s no reason there should be water inside that need draining.
Talking to @Tomster about this and he says that water will build up inside from condensation. It could also find its way in during high speed runs (compression of air creates condensation). There should be no need to equalize pressure if it were completely sealed.
Tomster
Beware of idiots
Tom
Its a F'in drain. On top of that Ford went out of their way to patent that part of the design.
Its a hollow space. Water will accumulate. Block any vent or drain off and you are asking for problems.
Tomster
Beware of idiots
Tom
Incorrect. Air expands and contracts. It also contains mositure which can condensate. If the core is not filled with foam, then there needs to be a vent.
Tomster
Beware of idiots
Tom
A refresh on OEM and aftermarket wing construction. The wing is manufactured assembling 4 different types of parts. There is the top portion, bottom portion, end plates, and mounting tabs. First, the upper portion of the wing and lower portion, which are pre-molded and fabricated separately, are bonded together to form the airfoil. The space between the two is hollow. There is no foam like with the multimatic wing. The end plates are attached to either side and then the mounting tabs are affixed. This leaves a problem, the wing is hollow. There has to be some kind of vent to allow for expansion and contraction of the air inside the foil. Also, water has to be able to escape.
https://www.mustang6g.com/forums/threads/water-in-my-carbon-fiber-wing.151537/
Tomster
Beware of idiots
Tom
Bottom of OEM CFTP wing
Top of wing
Tomster
Beware of idiots
Tom
is this an AC wing? Drain hole looks completely different from the one @Tomster posted.
My wing is OEM. Drains on top and bottom that both go into and out of the hollow body.
Tomster
Beware of idiots
Tom
If I ever get off my ass, the wing file I have allows me to have it cut from a solid piece of high density foam. All it would need is a CF wrap and finish.
