Centri Boys, Need Your Wisdom!
beefcake
Bethel
2018 Ford Mustang
Hey @Brad1810r80 I have a quick question regarding the e30 fuel you're running If you don't mind sharing...? How much ignition advance are you able to run up top? Does it cap out at 22* or can you be more aggressive with it or are you targeting less advance?
Thanks,
Tim
The v3jt might be beefcakes standard unit but as for vortech the standard unit is the v3 sci
again....its the same cost, it can be swapped at no charge.
and again, for the pump gas guy making 600-700 wheel, the smaller unit would actually have a better overall power band... of if you don't plan on going further, then it doesn't matter if it flows 5000 cfm, if your only using 900-1000, you want the unit that is closest to its peak efficiency at that cfm.
that would give you your quicker car
NO1CARES
FALLING WATERS WV
17 GTPP 5.2 TH400
so do you buy kits from vortech or do they send you to a dealer like beefcake?
beefcake
Bethel
2018 Ford Mustang
i'm vortech / paxtons largest dist for these kits.
you can buy direct, but we always take care of the guys
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Many don't understand that concept. Folks want to run some huge blower far below its efficiency range cause maybe one day they may turn it up.
NO1CARES
FALLING WATERS WV
17 GTPP 5.2 TH400
But get mad when a baby v3 on pump gas spanks them.
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
NO1CARES
FALLING WATERS WV
17 GTPP 5.2 TH400
A small blower maxed out can be really fast. Not many are into optimization.
Absolutely. My little v3si was enough to lift the head on my gen 2.
Brad1810r80
Huntsville AL
Brad
2018 Mustang 2018 F150
Guy on the ess thread did g2 vs g3 dyno with same pulley. The bigger supercharger made more hp and torque throughout the entire range.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Sounds like at that power level, the g3 was in its efficiency range.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
