What centri
joedrt73
georgia
2016 mustang gt base coupe
What centri uses a blow off valve and can control boost with a leash or a turbosmart valve
ahl395
Allan
Someone correct me if im wrong, but I don't believe any supercharger does this.
Boost is controlled by the size of the belt pulley. The smaller the pulley, the higher the boost.
What I think you're talking about is a wastegate setup on a centri. A wastegate can be installed on any of the three (Vortech,Paxton,Procharger) and used to control boost, and bring it on faster than without a wastegate. Instead of being pullied for 10lbs at redline and having a linear boost increase from 0, you can pulley for 20lbs and have the wastegate open at 10lbs. This will make you reach 10lbs much sooner than redline, and then stay constant, giving you a bump in mid-range power.
(20lbs just used as a simple example)
MyLilPony
Naw It's Stock
Prosper, TX
Kris
2015 Black GT, 18 JLUR, 15 JK
Someone correct me if im wrong, but I don't believe any centri supercharger does this.
What I think you're talking about is a wastegate setup on a centri. A wastegate can be installed on any of the three (Vortech,Paxton,Procharger) and used to control boost, and bring it on faster than without a wastegate. Instead of being pullied for 10lbs at redline and having a linear boost increase from 0, you can pulley for 20lbs and have the wastegate open at 10lbs. This will make you reach 10lbs much sooner than redline, and then stay constant.
^ What he said
There are only really two to choose from Paxton(Vortec but why?) and Procharger...
The only current plug and play WG solution is from Beefcake and it is only for the Paxton. Otherwise you have to fab yourself a WG on a PC setup.
beefcake
Bethel
2018 Ford Mustang
any setup can be made to do it.
we do have a wastegate setup for the paxton and vortech kits, i do have some guys that add a boost controller to them
Slamdcoop0428
SW Florida
2016 Mustang GT Premium auto
Yes it can be done. Pulley for the highest boost you want. Say 20 psi. Install wastegate with the lowest boost you want to run, say 10 psi spring. Install boost controler and up boost as you see fit. Itstead of controlling exhaust flow you are controlling boost pressure flow. Works both ways.
joedrt73
georgia
Yes I'm sorry I was mistaken on the vocabulary. Thanks for the info guys.
BrazukaV8
Los Angeles CA
Carlo
Mustang gt PP
What boost controller you recommend ?
