Center dash rattle - help please.
Vertas4
Czech Republic
Martin
Mustang GT 2017
Hello everyone,
I’m having this center dash rattle due to the plastic around the speaker as per the attached video.
Usualy it goes away after temperature change.
Does anyone know a way of fixing this?
What could I do to silence it?
I tried putting sound deadening all around the area, but that really didn’t help that much…
Thanks in advance for any help!
First Stang
2023 Mustang Mach1
I’ve been trying to find that rattle. Thanks for finding it. Will follow.
Timbuck
Australia
Tim
2017 s550 6r80
Inject any type of silicone sealant along that area , to stop the 2 surfaces rubbing together
Vertas4
Czech Republic
Martin
Mustang GT 2017
But what kind of surface is underneath it? It seems to me that the issue is under this plastic piece but I’m not really able to get under there.. atleast I don’t know how to.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
It's the plastic piece closest to the windshield. I have a match book inserted between it and the windshield and so far that has fixed it.
Timbuck
Australia
Tim
2017 s550 6r80
Take the speaker out to access that area. You could use just about anything to wedge between the to plastic surfaces rubbing together.
Vertas4
Czech Republic
Martin
Mustang GT 2017
Don’t think it’s the piece closest to the windshield.
Clearly you can see on the video that it’s the piece around the center speaker.
But I can’t figure out towards which other piece it’s making this sound, if it’s something even below it..
Vertas4
Czech Republic
Martin
Mustang GT 2017
So you think it’s some plastic underneath the one I’m showing on the video towards which it’s rubbing?
Timbuck
Australia
Tim
2017 s550 6r80
yes. it’s either that or some part of the dash frame work /support structure rubbing. Take the speaker out and give everything a push , pull and a poke and see what makes the noise stop.
thats where I would start Anyway.
geep81
Cleveland OH
2020 GT Premium
Do you suggest a way of solving it by any chance?
Thick foam padding/Tessa tape/felt padding?
Some weather stripping for windows could work.
Something that will apply a little pressure and keep the two elements separated while also giving some cushion is what I'd be looking to squeeze in there.
Vertas4
Czech Republic
Martin
Mustang GT 2017
Yes, I already put alot of deadening foam on the upper part all around the speaker, but the issue is underneath somewhere and the only possible entrence there is through the speaker hole … so quite limited.
Shame I can’t even find anywhere how it looks below there..
geep81
Cleveland OH
2020 GT Premium
I'd follow the advice the other poster here said, remove the speaker, get at the underside area and pad it up on the underneath.
K4fxd
NKY
I thought mine was the center speaker cover too. Hope you find it.
