C Pillar leak
JBR14
Dallas
Brian
2021 Mustang GT, 1995 EB Bronco, 1967 F100 SWB
We recently took my daughters 17 Ecoboost into the dealer to get the camera recall done. They looked at it, said it needed a new harness and ordered one. Apparently they are on backorder. Today, is the first time it has rained and we noticed it leaking near the C pillar on the passenger side. I am pretty sure its unrelated, but does the camera harness run behind the plastic panel above the 1/4 window? I looked and there is a harness there, but I assume its not the harness they are replacing.
Welcome to the site!
Here's the most common rear interior water leak threads, it should help with your concern.
CHECK THIS THREAD, it's for 3rd brake light leak repair with instructions:
https://www.mustang6g.com/forums/threads/issue-with-third-brake-light-water-leak.97131/
Also here's more S550 water leak threads that may help if it's not the 3rd brake light:
https://www.mustang6g.com/forums/threads/trunk-water-leak-did-i-repair-or-cause-issue.148040/
https://www.mustang6g.com/forums/th...ear-quarter-panels.143545/page-2#post-2940946
https://www.mustang6g.com/forums/threads/trunk-leaking.15806/#post-2695720
https://www.mustang6g.com/forums/threads/water-in-trunk.88100/#post-1959273
I hope the above is helpful
JBR14
Dallas
Brian
Thanks. After posting this, I just went and ran water over the roof. It is the 3rd brake light. Water is coming in where the clip that snaps in on the passenger side is located. I suppose it will be covered under the Ford ESP that I purchased. Just annoying.
Good to hear you found the source and post back an update once it's been repaired.
