Boostane? With 91oct?
Einstein_nikola
Chicago IL
Sir Galahad
2015 Mustang GT PP
Im currently FBO CJ On a ESS setup on 120mm pulley Gen2, When I go WOT I dont see positive knock or nothing but was wondering if I added Boostane and if how much to mix, would I need another tune or can I just add some and expect more power?, would my spark plugs be bad bad?
Thanks !
LOL WUT
Illinois
19 GT
No need for a new tune. There is a chart on the can that tells you how much to add to meet a specific octane. And your plugs will get coated in orange stuff from using it.
Einstein_nikola
Einstein_nikola
Chicago IL
Sir Galahad
2015 Mustang GT PP
Is that oranage stuff bad for the plugs ? Should I be concerned? Or running race gas a better option?
LOL WUT
Illinois
19 GT
Honestly no idea. Lots of people here run boostane on every tank and it don’t seem to have negative impacts. Personally, if I did run it, I’d just pull my plugs and clean them at a certain interval. Race gas is another option but likely quite a bit more expensive.
Einstein_nikola
Einstein_nikola
Chicago IL
Sir Galahad
2015 Mustang GT PP
Well that helps, thank you!
Zrussian13
Phoenix
If you run boostame consistently you will need to change your plugs more often. I was doing 10k plug change intervals when I ran 8oz of boostane per tank. I try not to go over 8k in between changes or cleanings now because I'm running 16oz per tank. The first set of plugs I pulled out where caked up by 11k miles or so but since I started pulling them sooner, they haven't looked too caked up. Just orange.
Einstein_nikola
Einstein_nikola
Chicago IL
Sir Galahad
2015 Mustang GT PP
So I notice theres 3 kinds of boostane, which one do you recommend and what's the difference between all 3?
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
I had ran MMT products for the last 24 years. The orange residue is harmless. I ran it for complete 10-20K mile seasons every year. Never needed to touch a spark plug. One tank full of straight 93, will clean the plugs 90%.
Einstein_nikola
Einstein_nikola
Chicago IL
Sir Galahad
2015 Mustang GT PP
Use Professional.
So if I pump lets say 8 galons only, it says to use 0.32oz only per gallon so thats only a total of 2.52 oz that ima pour to mix in with 91 since im using that?
Cory S
Bradford, NH
Cory
Directions and mixing chart is on the back. It’s not rocket science. :)
junits15
MA
Justin
2019 Mustang GT
TEXAS HEAT
TEXAS
2019 Mustang GT PP1 A10
It's literally only 2oz of Boostane pro to push 93 octane to 95. Super easy and economical way to prevent knock.
2oz per gallon of 93 octane, correct?
